Topic: Help with a project, having trouble with Serial and Keyboard (Read 82 times) previous topic - next topic
Mayonice
Currently im working in a project were i can select with a knob a number and when i press it the keyboard will type it. The problem is that i dont know if this is even possible, for example If my potentiometer is between 0 and 100 (max is 1023) and i press the button the arduino should type 3. Here is my code, thanks in advance!
Code: [Select]
#include "Keyboard.h"
const int buttonPin = 4;          // input pin for pushbutton
int previousButtonState = HIGH;
  pinMode(buttonPin, INPUT);
  Keyboard.begin();
// the loop routine runs over and over again forever:
  int buttonState = digitalRead(buttonPin);
  int val = analogRead(A0);
  Serial.println(val);
  delay(1);
  if ((buttonState != previousButtonState)
      && (buttonState == HIGH)
      && (val == 0)) {
    Keyboard.println("3");
      && (buttonState == HIGH)) {
DKWatson
There's nothing wrong with your code or logic, except you should avoid testing analog inputs against being exactly a specific value as they tend to fluctuate. In each case you are testing the button state so how about something like this.
Code: [Select]
if ((buttonState != previousButtonState) && (buttonState == HIGH))
    switch (val)
        case 0 ... 100:
        case 101 ... 200:
        case 901 ... 1000:
        default:
Live as if you were to die tomorrow. Learn as if you were to live forever. - Mahatma Gandhi
