Topic: Ping Libary for Ethernet v2.0 Libary (Read 1 time) previous topic - next topic
stevefromNewcastle
I have a MKR Zero and Ethernet shield and I am looking for a working Ping libary. The ICMP Ping Libary https://playground.arduino.cc/Code/ICMPPing uses memebers in the w5100 class that are no longer present. I was wondering if someone can point me in the right direction to have a look at porting the ICMP code for the new Ethernet Libary.
Cheers
Steve
Juraj
use last 1.x version of Ethernet library
stevefromNewcastle
Does the last version of Ethernet 1.x support the w5500 chipset on the MKR Ethernet Shield?
Thanks
Steve
Juraj
Thanks
Steve
sorry, no
Juraj
try to use the Ethernet2 library. replace all W5100 occurrences in ping library with w5500 (lower case w!). it compiles
orichienal
#5
Mar 06, 2019, 03:07 pm Last Edit: Mar 06, 2019, 03:33 pm by orichienal
hiho
unfortunately that does not work either
have everything replaced, with big and small "w"
I search the fingers in the net bloody because I really need icmpping with the ethernet 2.0 library
I hope someone can help me
if i find another solution i will publish it here for everyone else with this problem
problem description at github
khhoa
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\Administrator\Documents\Arduino\libraries\icmp_ping\ICMPPing.cpp: In member function 'Status ICMPPing::sendEchoRequest(const IPAddress&, const ICMPEcho&)':
C:\Users\Administrator\Documents\Arduino\libraries\icmp_ping\ICMPPing.cpp:184:11: error: 'class W5100Class' has no member named 'send_data_processing'
     W5100.send_data_processing(_socket, serialized, sizeof(ICMPEcho));
C:\Users\Administrator\Documents\Arduino\libraries\icmp_ping\ICMPPing.cpp: In member function 'void ICMPPing::receiveEchoReply(const ICMPEcho&, const IPAddress&, ICMPEchoReply&)':
C:\Users\Administrator\Documents\Arduino\libraries\icmp_ping\ICMPPing.cpp:207:19: error: 'class W5100Class' has no member named 'getRXReceivedSize'
         if (W5100.getRXReceivedSize(_socket) < 1)
C:\Users\Administrator\Documents\Arduino\libraries\icmp_ping\ICMPPing.cpp:219:9: error: 'class W5100Class' has no member named 'read_data'
   W5100.read_data(_socket, (uint16_t) buffer, ipHeader, sizeof(ipHeader));
C:\Users\Administrator\Documents\Arduino\libraries\icmp_ping\ICMPPing.cpp:229:9: error: 'class W5100Class' has no member named 'read_data'
   W5100.read_data(_socket, (uint16_t) buffer, serialized, dataLen);
exit status 1
Error compiling for board Arduino/Genuino Uno.
Please help me fix this error
mclareniak2
Hello.
Any change? I have the same problem as khhoa writes.
orichienal
Pete_UH
This doesn't answer the original question, but it may help anyone else trying to get Ping to work on 1.8.9 and finding this thread when Googling for the answer.
https://forum.arduino.cc/index.php?topic=636589.0
johnthesoftware
Just saw this. I'm using v2.0 from here...
https://github.com/arduino-libraries/Ethernet
I don't know much about Arduinos but I know a bit about about networking and I hadn't expected ping to work, but it did.  I'm using a w5100 on a mega2560.
I expect I've misunderstood something.
John
