Topic: How to get servo angle to change based on a mathematical function (Read 292 times) previous topic - next topic
sierrahorangic40
I'm aware that you can program servos to move to a certain angle like this:
Code: [Select]
servo1.write(180); // set servos to original position
servo2.write(0);
delay (500);
 servo1.detach();
 servo2.detach();
I was wondering if there is a way to get the servo to change continuously based on a mathematical function you could declare at the beginning?
jremington
Code: [Select]
   servo.write(your_function());  //function returns values 0 to 180
There is rarely a need to use servo.detach();
sierrahorangic40
Can you help me with this part?
I want my servo angle be [ arctan(5t/8.255) ] based on the variable of t (seconds)
I've been trying to declare different variable and even downloaded a couple libraries, but it's not working and I'm having problems.
This is the base code that I keep trying to get to work:
Code: [Select]
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include <Servo.h>
#include <math.h>
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Servo servo1;
Servo servo2;
Serial.println("wrist");
AFMS.begin();
servo1.attach(10);
servo2.attach(9);
servo1.write(180);
servo2.write(0);
 servo1.write(double  atan2 (double __y, double __x);
jremington
You are attempting to run before you can crawl. There is nothing in your code that keeps track of time, and you haven't yet learned how to use built in functions.
I suggest that you start from the beginning and work through some of the example projects that come with the Arduino software: blink an LED, time events, read a pushbutton, etc.
If you don't want to do that and instead want someone to write the code for you, post on the Gigs & Collaborations forum section. You may be asked to pay for the help.
