Topic: Buying ultrasonic transducer (Read 344 times) previous topic - next topic
dongjee33
Hello.
Is there any qebsite that I could buy ultrasonic transducer?
I find 1.5mhz (or it will find 1.4 or 1.6) long bandwidth frequency transducer.
Or is it possible to make transducer with piezo crystal?
wvmarle
A quick Google search turned up several different websites.
Probably the other usual suspects such as Amazon, Aliexpress, Taobao, Element14, Mouser, Digikey etc. also have such transducers.
So what's your problem, really?
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
6v6gt
Here is an example of an ultrasonic transducer
But your frequency range around 1.5MHz is well above the ultrasonic range and is well into the radio frequency spectrum.
Maybe say a bit more about what you are intending to do.
dongjee33
could I make ultrasound transducer?
Is it just piezo crystal and pulse Voltage, so If I prepare piezo crystal and soldering up and down part,
then give pulse signal, Is it a ultrasound transducer?
6v6gt
Make an ultrasonic transducer ? I'm not sure about that. Maybe some one else can answer. However, at less than a dollar for a ready made one, personally, I'd buy one.
I guess that you can use the arduino tone() function to generate signals in at least the low ultrasonic range to feed into the transducer.
MrMark
Hello.
You haven't said what you want to do with this transducer, but for many applications transducers are operated at their resonant frequency to maximize efficiency.  Thus you would have to use a piezo device appropriate to your operating frequency.  In addition any mounting, enclosure, and interface to the transmit medium will affect the tuning of the piezo device which is very much a non-trivial design task.
That said a wide range of devices is available: https://www.steminc.com/PZT/en/piezo-disc
MarkT
And there's a difference between a transducer designed for air and one designed for solids/liquids, as the
acoustic impedance is utterly different for the two regimes.
