Topic: Punctuation Marks and Etc. of the English Language  (Read 8441 times) previous topic - next topic
GolamMostafa
Oct 24, 2018, 07:39 pm Last Edit: Oct 30, 2018, 05:36 am by GolamMostafa
Usually efficiency is greater when input and output voltages are close to each other, so daisy-chaining
is likely to mean each converter is being more efficient than with independent converters, but that won't translate to overall efficiency unless the lower voltages are using much less power that the higher voltages.
In our non-native schools, we were asked to sit for English Language punctuation tests. If the quoted sentence would be my test, I would do the following. My query is: Should the punctuation test be different for natives and non-natives?
Usually efficiency is greater when input and output voltages are close to each other; so, daisy-chaining
is likely to mean each converter is being more efficient than with independent converters; but, that won't translate to overall efficiency unless the lower voltages are using much less power that the higher voltages.
(I have applied the rules of independent clause and the transitional adverb.)
Robin2
Two or three hours spent thinking and reading documentation solves most programming problems.
Qdeathstar
#3
Oct 27, 2018, 05:44 am Last Edit: Oct 27, 2018, 05:49 am by Qdeathstar
Hi.
If you was born here is your god given right to language how yous want if ya ain't you got to earn it. I don't go round correcting mexicans on the correct pronounsation of taco bell, now, do i? #MAGA
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
Robin2
Punctuation has two separate purposes
1. To make it easier to understand written text
2. To create employment for language teachers.
...R
larryd
ifyoudonthavesomekindofrulesthenthingscanbeabitdifficulttofollowanditbecomeshardertocommunicate
alsoihavealwaysthoughtheenglishinenglandwasabithardtounderstand
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
Patrick_M
per inserire (lo sketch) il programma, dall'IDE clicca modifica, clicca copia per il forum poi vieni qui e incolla nel tuo post (ctrl+v) ;)
GolamMostafa
#7
Oct 28, 2018, 07:29 am Last Edit: Oct 28, 2018, 07:29 am by GolamMostafa
If you don't have some kind of rules, then things can be a bit difficult to follow; and, it becomes harder to communicate; also, I have always thought (that) the English in England was a bit hard to understand.
Robin2
Presumably you are now referring to spoken English rather than written English.
One needs to attune one's ears to the local accent. I'm Irish and I was at a business meeting in Texas  when one of the experts that we were visiting arrived late due to a delayed flight. Having got used to US accents I could not understand the newcomer for about 20 minutes until I realized he was speaking with a Scots accent. Then there was no problem understanding him.
...R
Budvar10
In my opinion this is too much of punctuation. Or am I wrong and it is correct? Can somebody with native English and good knowledge of grammar, write it correctly?
P.S.: I'm native Slovak. Our language has very complicated grammar rules, much more than English. We are using comma frequently, semicolon less. The sentence above uses both in rate, which would be in Slovak language criteria simply "too much". I am suspicious that it is not correct.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
Robin2
#10
Oct 29, 2018, 11:13 am Last Edit: Oct 29, 2018, 11:15 am by Robin2
I am a native English speaker but I won't pretend to be a grammar expert. I would write that sentence like this as two separate sentences. In general shorter is better.
If you don't have some kind of rules then things can be a bit difficult to follow and it becomes harder to communicate. Also, I have always thought (that) the English in England was a bit hard to understand.
...R
Budvar10
Thank you Robin. I've expected 2 sentences.
ardly
Here is text from an autocue that missed some commas;
"This is BBC World News, I am Jonathan Charles kept hidden for almost two decades and forced to bear children...."
https://youtu.be/a5108erygkM
Both native and non-native speakers should have the same test for punctuation as the meaning of sentences can change completely different with different punctuation.
Having said that non-native speakers can often simplify the grammer of spoken English in non-standard ways that are are perfectly understandable and unambiguous. No doubt, over time, these simplifications will become "standard" English.
"Facts do not cease to exist because they are ignored" - Aldous Huxley
GolamMostafa
As a non-native, I need to re-write the above sentence as follows just to get pass of the English as a second language.
If you don't have some kind of rules, things can be a bit difficult to follow; and, it becomes harder to communicate.
I must honor the rules of combining together the dependent clause, independent clause and transitional adverb through correct use of the punctuation marks.
ardly
I see what you mean you are actually having to be more dilligent than the native speaker.
I only speak one language and I don't have a formal understanding of it's grammatical rules. I am sure that is a bad thing. I suppose though as a non-native a lot depends on what level of study you are undertaking. If you are studying at University level being tested on a formal understanding of the rules probably makes sense.
