Topic: pH sensor, Salinity sensor and Dissolved Oxygen sensor. (Read 30991 times) previous topic - next topic
Hawhaw
Is it possible to make those sensors using Arduino? And can you use just one Arduino board for all those sensors? And I'm also beginner on Arduino and programming.
FirstName
#1
Mar 08, 2013, 12:11 am Last Edit: Mar 08, 2013, 12:17 am by FirstName Reason: 1
Yes i think. In two words. First you need to find a data-sheet of you sensor (probe). Then you can connect probe directly to your arduino board. Or first make a little intermediate board to regulate your current tension etc. But i think in most of probe (sensor) you can find already intermediate board (look the price).
For example.
robtillaart
You can connect (most) existing sensors to the Arduino, you should look at the voltage level of course.
PH - there exists a nice sensor from atlas scientific which is discussed on the forum many times (google arduino ph atlas scientific)
Salinity - I think by measuring resistance of the water?
Oxygen - ?
you could be inspired by this - http://nznano.blogspot.nl/2011/12/homemade-spectrometerspectrophotometer.html -
(there are more spectrometers out there)
DOn't know how well they will detect dissolved atoms...
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Hawhaw
Thanks for your replies. I guess I'll have to learn more about Arduino then
michinyon
Quote
What do you mean by this ?
If you have got a sensor from somewhere,   it is almost certainly possible to use it with an arduino.  The exception may be some sensors which use high voltage.
But can you "make" these sensors with an arduino ?   Like "make your own" ?  Probably not.  The operating principles of these sensors are not simple and require materials and fabrication techniques that you probably don't have.
ODwyerPW
What you can do with the Arduino that is very useful is to receive signals from these probes/circuits and make them available for display, data archiving and control.
There are a number of folks doing things with these probes to control their aquariums. Just search on Aquariums. I've seen handmade ph, temperature and conductivity probes. I recall one user that has even custom built PH, ORP and Conductivity Shields. (search Arduarium)
BTW, Salinity can be calculated from a conductivity probe.  In fact, Conductivity, Salinity and Total Dessolved Solids can be derived together.
Atlas Scientific has nice stuff (I am using it for two projects that involve Arduino for prototyping). It is expensive, but is pretty much system agnostic (they standardized on serial communications to interface with their sensor/circuitboard combos.)
Quiero una vida simple en Mexico...nada mas.
michinyon
Conductivity is easy to measure.   You can easily calculate a dissolved salt amount which is equivalent to that,   provided you are happy to assume that the conductivity is caused by salt and not by something else.
mchetan133
Please provide me the links where I can buy Dissolved oxygen and salinity sensor
ODwyerPW
erikyo
I know this post is old but if you're still interested I've done a function that allows you to calculate the maximum concentration of dissolved oxygen in the water... not by reading a sensor but calculating with temperature and (optionally) with pressure and tds ppm.
It can help to establish maxDO (but not a real reading!) and automate, for example, an air pump in hydroponics.
cheers, Erik
gist: https://gist.github.com/erikyo/3baa42d4d1f07e93913eaedb76fe64dc
Code: [Select]
// --------- Max Dissolved Oxigen Saturation ------------//
// Equation for the Henry coefficient as a function of temperature and salinity is used to calculate values
// for unit standard atmospheric concentrations (USAC) in freshwater and seawater in equilibrium with air at a total pressure
// of 1 atmosphere. It is estimated that the possible error in the new USAC values is no greater than $\pm 0.1%$ and probably less.
// Tables and equations are presented for obtaining accurate USAC values in the ranges $0^\circ < t < 40^\cir C and 0 < S < 40$.
// Simple procedures are given for calculating standard atmospheric concentrations at pressures different from 1 atm.
// Reference https://water.usgs.gov/software/DOTABLES/
// Dissolved oxygen (DO) solubility over a range of user-specified values for
// water temperature, barometric pressure, and salinity or specific conductance.
// Low memory usage function for Arduino, esp 8266 who can estimate the DO,
// useful for water testing, hydroponics and aquarium automation etc
// Functions
float getMaxDO(float wt, float pres = NULL, int ppm = NULL) {
  float sat,tk, bp, sal, sc;
  // compute Kelvin temperature
  tk = wt + 273.15;
  // compute oxygen solubility in freshwater at 1 atm and input temperature
  sat = exp(-139.34411 +(1.575701E5 +(-6.642308E7 +(1.2438E10 -8.621949E11/tk)/tk)/tk)/tk);
  // if have pressure data
  if (pres) {
    // convert bp to atmospheres
    bp /= 1013.25;
    // compute pressure correction
    float u, theta;
    u  = exp(11.8571 +(-3840.70 -216961/tk)/tk);
    theta = 0.000975 -1.426E-5 * wt +6.436E-8 * wt * wt;
    sat *= (bp - u)*(1 - theta * bp)/((1 - u)*(1 - theta));
  // if ec
  if (ppm) {
    // will use the original dotable variable name
    sc = ppm;
    // convert ppm to salinity
    sal = 5.572E-4 * sc + 2.02E-9 * sc * sc;
    // compute salinity correction
    sat *= exp(-1 * sal * (0.017674 +(-10.754 +2140.7/tk)/tk));
  return sat;
  // your vars
  float my_wt = 25.00;
  float my_pres = 1010.00; // input pressure expressed in millibars
  int my_ppm = 1000; // input your TDS PPM
  float MaxDO; // our return var
  MaxDO = getMaxDO(my_wt, my_pres, my_ppm);
  Serial.print("Max Dissolved oxygen (DO) solubility of ");
  Serial.print(MaxDO);
  Serial.print("mg/L at ");
  Serial.print(my_wt);
  Serial.print("°");
  if (my_pres) {
    Serial.print(" with ");
    Serial.print(my_pres);
    Serial.print("millibars");
  if (my_ppm) {
    Serial.print(" and at ");
    Serial.print(my_ppm);
    Serial.print(" TDS PPM");
http://www.codekraft.it
https://github.com/erikyo
woti
Now there are dedicated dissolved oxygen sensors that can be directly interfaced with arduino (https://www.ebay.com/itm/254255019357)
always_innovating
try searching for a Clark Electrode for pO2 measurements.
