Topic: Tracking a non-servo (Read 424 times) previous topic - next topic
thetalkingjeff
So far I have this code hooked up to a motor that it says was a servo, but it is not (sm-s4303r-ccw).
Code: [Select]
#include <Servo.h>;
Servo myservo;
int pos = 0;
void rotate() {
  for(pos = 0; pos < 180; pos += 1)
    myservo.write(pos);
    delay(15);
  for(pos = 180; pos>=1; pos-=1)
    myservo.write(pos);
    delay(15);
    //delay(86400000);
  myservo.attach(9);
  myservo.write(0);
  rotate();
Is it possible to track the position with a non-servo, because I recently found out that it is not a servo. This code just makes it turn one way forever.
AWOL
Are you saying it is a "continuous rotation "servo""?
You can't know or set the position of such a device. It is pointless trying.
thetalkingjeff
Ok. Thanks. Do you have any clue where I can buy a SERVO that isn't continuous rotation but can turn over 360 degrees?
slipstick
Yep, do a search for sail winch servos. Most have full positional control over about 4-6 complete rotations.
Steve
thetalkingjeff
PaulS
Quote
At a (not insignificant) cost.
slipstick
If you know a way of achieving the same end with no significant cost I''m sure the OP would be pleased to hear about it.
There are relatively inexpensive winch servos (£12-15) but given their intended purpose they're all fairly large. You don't really see any very small very cheap things like SG90 equivalents.
Steve
Northof49
Would a stepper motor (with gear reduction if you need more torque) work for you?  Is it enough that you know the present position of the motor by counting steps from a home position? If so, a stepper motor might work for you.
PaulS
Quote
I don't. I was just pointing out that you can't get something for nothing. There are always trade-offs - more hardware (encoders), more cost, larger size. OP needs to determine where the trade-offs outweigh the benefits for his/her project. Maybe a different kind of motor would work, instead.
