Topic: Using "return" and its associated syntax (Read 3113 times) previous topic - next topic
tgross
I'm using a ds1307 chip to bring real time into my Ard Pro Mini and someone posted some code out here in 2008 that looks like what I want.  However I don't exactly understand the syntax that's being used here.   My problem is that I do need to change hex values from the ds1307 to dec values and I'm having a problem doing this so far.   This is the code that I think I need to utilize but I don't exactly understand it's syntax:
int DS1305::bcdToDec(const byte bcd) {
      return ((bcd / 16 * 10) + (bcd % 16));
This was posted by windmis in 2008.  My questions are as follows:
On this code what's going on with the double colon, "::" ?
After byte there appears to be a function name and then a variable or vice versa, how does this work? ie, "byte DS1305::bcdToDec".
After the function name there are three variables in the parenthesis,  "(const byte bcd)" .   I guess this is a variable, datatype, variable ?
Your help would be appreciated.  Thank you,
Tim
Korman
The :: indicates that you have a method bcdToDec of the class DS1305. If you have an object of this class, you can access this functions as:
Code: [Select]
DS1305 foo;
int baz = foo.bcdToDec (35);
The "const byte bcd" just means there's one parameter called bcd of type byte which isn't expected to changed inside the function (the const part). The last const is mostly a hint for the optimiser so that it knows it can do nasty things without having to worry about restoring the original value.
Korman
robtillaart
Quote
This means this is a function with the name  "bcdToDec"
+ which is part of the class named "DS1305"
+ needing a parameter named "bcd" of the type const byte
+ and this function retuns an int.
If you want to have three parameters you need to separate them with ,  e.g  int max(int x, int y) ....
more see - http://www.arduino.cc/en/Reference/FunctionDeclaration
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
tgross
robtillaart and Korman thank you for your advice.   This will certainly help.   And the reference to the function syntax was a magic bullet.    Thanks guys!
Tim
