Topic: 8x8x8 Led Cube inverted, help needed (Read 3840 times) previous topic - next topic
trunet
I'm trying to do my 8x8x8 led cube as showed on http://www.instructables.com/id/Led-Cube-8x8x8/.
I actually made the led cube and the latch array board. I put the transistors on my breadboard and started to test with my arduino. All the leds lights up and stays on, no effects, nothing.
So, I started debug the circuit and after 2 days I discovered the big, HUGE mistake. I soldered all 512 leds inverted(instead anodes down I soldered cathodes down on columns).
So, is there an easy way to remedy the situation? I really didn't like to solder all my led cube neither loose my latch board. If I have to choose I prefer to make another latch board. As I said the NPN transistors are on my breadboard(easy to change).
Latch board is a 74HC138N(to drive CP pins) and 8 x 74HC574N. Schematic available on http://www.instructables.com/id/Led-Cube-8x8x8/step30/Build-the-controller-layout/
Thanks,
Wagner Sartori Junior
3dprinter
:smiley-sweat: - yeah, I feel your pain.
Anyhow, here is a simple single diode circuit where I have "accidentally" put the LED in the wrong way round on the left side, and on the right side I've turned the circuit round to match. I switch + and -, I've swapped the NPN for a PNP. This is sort of the way you have to go, I think (have not tested it) This way you ned change anything on your multiplexers or such like.
trunet
Thanks for the response.
Do you know a good PNP transistor to switch 1.28A and hFe(min) 160?
3dprinter
