Topic: ^ exit status 1 expected primary-expression before '||' token (Read 388 times) previous topic - next topic
PaulSn
I am getting this error  while compiling and I'm not sure why. I'm new to arduino, so go easy on me. Please advise, thanks!!
error:
uav_payload_receiver:33: error: expected primary-expression before '||' token
     if(input == 0000) || (digitalRead(10) == LOW) {//if off code is received and no test button, all off and servo to 90
uav_payload_receiver:43: error: 'input' was not declared in this scope
     if(input == 1111){//if on code is received
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SoftwareSerial
Using library Servo at version 1.1.2 in folder: C:\Program Files (x86)\Arduino\libraries\Servo
exit status 1
Code: [Select]
  5 channel remote receiver for UAV tooling. 1
  servo rotator and 4 power FETs
  Author Paul Sneed
  based on:
  HC-12 Momentary Button Receive
  Author Tom Heylen tomtomheylen.com
#include <SoftwareSerial.h>
#include <Servo.h>
SoftwareSerial mySerial(0, 1); // RX, TX
Servo servo_9;
  mySerial.begin(9600);
  pinMode(10, INPUT);
  pinMode(13, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  servo_9.attach(9);
   if(mySerial.available() > 1){
    int input = mySerial.parseInt();//read serial input and convert to integer (-32,768 to 32,767)
      digitalWrite(13, LOW);
      digitalWrite(4, LOW);
      digitalWrite(5, LOW);
      digitalWrite(6, LOW);
      digitalWrite(7, LOW);
      servo_9.write(90);
      delay(20); // Wait for 20 millisecond(s)
    // take code 1111 to rotate servo45
    digitalWrite(13, HIGH);
    servo_9.write(45);
    if(input == 2222) {
      // take code 2222 to turn on FET2
      digitalWrite(4, HIGH);
      if(input == 3333) {
       // take code 3333 to turn on FET3
        digitalWrite(5, HIGH);
        if(input == 4444) {
          digitalWrite(6, HIGH);
          if(input == 5555) {
            digitalWrite(7, HIGH);
            if (digitalRead(10) == HIGH) {
              // test button, all fets on and servo45
              servo_9.write(45);
  mySerial.flush();//clear the serial buffer for unwanted inputs
  delay(20);//delay little for better serial communication
AWOL
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
DKWatson
Yes, your first nested if statement needs some more parentheses.
Second issue is that input is being declared inside the first if test and as such has no scope in the next. You need to move int input; out of the if, just inside loop(). Replace statement in if with input = mySerial.parseInt();
Live as if you were to die tomorrow. Learn as if you were to live forever. - Mahatma Gandhi
PaulSn
great, thanks!.. I'm not sure I completely understand..
does int input = mySerial.parseInt();//read my.Serial input and convert to integer (-32,768 to 32,767) need to be out of the loop?, up near int pos = 170;?. or are you saying to make it input = mySerial.parseInt(); where it is, and lose the int?.
I got this one to verify in arduinoIDE, I have not uploaded it yet.
You all are awesome!..
Code: [Select]
  Author Paul Sneed
  based on:
#include <Servo.h>
SoftwareSerial mySerial(0, 1); //RX, TX
Servo servo_9;
int pos = 170;
  pinMode(10, INPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  servo_9.attach(9);
    if (mySerial.read() == 0 || digitalRead(10) == LOW) {
    // no inputs, all low and servo 90
    servo_9.write(90);
  if (mySerial.read() == 1111) {
    servo_9.write(45);
    if (mySerial.read() == 2222) {
      if (mySerial.read() == 3333) {
        if (mySerial.read() == 4444) {
          if (mySerial.read() == 5555) {
              // test button, all on and servo45
              servo_9.write(45);
MorganS
Your blocks aren't lined up properly. Use the auto-format tool in the IDE to fix it.
You seem to read an integer in the variable input and then ignore that value, trying to read from mySerial again and again. The mySerial buffer will be empty by that point.
Also, the single character read by read() could never contain the value 1111. It is simply too small for a number that big.
"The problem is in the code you didn't post."
PaulSn
ok.. should I use something like a if (mySerial.read() == 1) or something?. the information it reads is not critical, I can have the transmitter send whatever this receiver wants to read. I think the transmitter/remote is working, I tested it on the serial monitor and the button presses send the serial print as expected (I'm sure I'll be here to fix that one also, lol).
I ran the auto-format, not sure what changed. also deleted a bunch of the delay(20);s, I don't think they are necessary until the last one.
how do I fix the mySerial.read() parts?, and the parseInt parts?.
Thanks!
MorganS
You fix it by using the value you read instead of trying to read again.
From the Arduino's point of view, Serial is glacially slow. It is like a friend sending you an email with only one character and one whole week waiting to get the next character in your mail.
Yes, reading one-character commands is easiest, if the commands are all simple. The only problem with your suggestion is that you cant type 1 on your keyboard. Try this...
Code: [Select]
char inputChar;
if(mySerial.available()) {
  inputChar = mySerial.read();
  switch(inputChar) {
    case '1':
      //do command 1
    case 'g':
      //do command g
    case '\n':
    case '\r':
      //ignore newline and linefeed
    default:
      Serial.print("Unrecognised command: ");
      Serial.println(inputChar);
