Topic: Error: verification error, first msmatch at byte 0x0000 & TX+RX LED is always on (Read 241 times) previous topic - next topic
boboyuan
I programmed the ATMega168 board for a while without any problems, but suddenly got an error (marked red) uploading the LED-Blink program (during reading on-chip data):
Code: [Select]
Arduino: 1.8.7 (Windows 10), Board: "Arduino Duemilanove or Diecimila, ATmega168"
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM9
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega168
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no        512    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     16384  128    128  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9406 (probably m168)
avrdude: reading input file "C:\Users\Bowen\AppData\Local\Temp\arduino_build_613756/Blink.ino.hex"
avrdude: writing flash (930 bytes):
Writing | ################################################## | 100% 0.75s
avrdude: 930 bytes of flash written
avrdude: verifying flash memory against C:\Users\Bowen\AppData\Local\Temp\arduino_build_613756/Blink.ino.hex:
avrdude: load data flash data from input file C:\Users\Bowen\AppData\Local\Temp\arduino_build_613756/Blink.ino.hex:
avrdude: input file C:\Users\Bowen\AppData\Local\Temp\arduino_build_613756/Blink.ino.hex contains 930 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.77s
[color=red]avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x00 != 0x0c
avrdude: verification error; content mismatch[/color]
avrdude done.  Thank you.
the selected serial port
 does not exist or your board is not connected
There was no error on compilation. I'm sure I have chosen the right port and the right board in the Arduino IDE, so this shouldn't be the problem. Another unusual observation is that the TX & RX LED is both set on high even if I don't upload anything and the LED 13 is glowing very faintly. I've tried to reprogramm the device with MProg, turned the baud rate, but nothing helped. After looked at some forum posts, I suspect that the bootloader is damaged, but correct me if this is wrong. What should I do to solve the problem? Or is the board completely trash?
It would be nice, if somebody could help me to solve this problem.
thanks.
