Topic: Need to hire a programmer near Atlanta, GA (Read 274 times) previous topic - next topic
BIAW
Hello!
I have a project that needs to be completed very quickly.
It is a data logger that writes the data from two separate rs-485 channels, a temperature sensor and also records if a 12vdc signal is present. Real time clock with a sd card will be used for recording and time stamp.
Please reply via text or here if you are interested.
Thank you,
Michael
404.seven nine seven. four 4 six 8
wvmarle
Unless you really have a lot of data to record, I'd use an ESP8266 using its internal Flash (up to 3 MB of storage) instead of an external flash. Best if there's WiFi available at the location as you don't need the RTC (get the time from NTP), and you can download the data logs through a simple web interface instead of removing the SD card.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
