Topic: "file open error"when using Sdfat.h to creat a file and log some data (Read 594 times) previous topic - next topic
taotao34123
hi,I am totally a newer of arduino , I want to log data to SDcard. After several days' study ,I know that the SdFat library may be a good choice. then I copied some codes from website and modified them and  begin my work. these codes modified are as below:
#include <TimerOne.h>
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SdFat.h>
SdFat SD;
SdFile myFile;
   pinMode(10, OUTPUT);
   digitalWrite(10, HIGH);
   Serial.println("Initializing SD card...");
   if (!SD.begin(10, SPI_HALF_SPEED)) { Serial.println("initialization failed!");return; }
   Serial.println("initialization done.");
   int ts = 2000;
      Serial.println("wolaile,wolaile--1234567812345678---1234567812345678---");
      sprintf(filename2, "%0d", fileindex);
      strcat(filename2, ".txt");
      fileindex = fileindex + 1;
      Serial.println(filename2);
      Serial.println(xiestring);
      filerecord();
      delay(10000);
void filerecord()
   Serial.println("filename2");
   myFile = SD.open(filename2, O_WRITE | O_CREAT | O_AT_END);
   if (!myFile) { Serial.print("file open error!");}
   Serial.print("Writing to test.txt...");
   myFile.println("test,test,test,I just want to do test,GOD help me!");
   myFile.close();
   Serial.println("done.");
these above are the SD operation parts of my code ,it does not work , even worse ,it stopped other parts of my codes from working ,I donot know why .
I am not really know the usage of "SdFat SD;" or "SdFile myFile;", I donot know much about the difference between  "SdFile myFile;" and "File myFile;", it seems both of them are OK in VS2017, no warning ,no error ,compling succeed, but neither of them work.
I once succeed , i.e. the SD file creation operation had experienced some success(otherwise I may giveup , wonot come to the forum for help), after my stupid modification , it turned bad. I can not find where I badly modified .
These codes are parts of my codes ,I carefully copied to here , to ensure offering enough information to everyone to help me .  Were the whole codes necessary , I will post all of them here . thank you !
taotao34123
besides , for my instance , somewhere I see :
SdFat SD;
and ,otherwise I see:
SdFile myFile;
myFile.open(filename2, O_WRITE | O_CREAT | O_AT_END);
are they absolutely the same ?  are they all right usage ?
