Topic: Firmware Update 1.2.1 - available now, with BLE mode (Read 8088 times) previous topic - next topic
sandeepmistry
Nov 14, 2018, 04:40 pm Last Edit: Nov 16, 2018, 07:33 pm by sandeepmistry
Hi everyone,
Today we are pleased to announce version 1.2.1 of the Arduino NINA-W102 firmware, which includes initial BLE support. For a full list of changes to the firmware, please see the CHANGELOG on Github.
There is a new ArduinoBLE library available to go along with with the firmware release. The library is currently in "beta". and only supports BLE peripheral mode. Please note, WiFi functionality (using the WiFiNINA library) cannot be used at the same time as BLE.
Here's are some steps to get you started:
  • Download and install the hourly Arduino IDE build.
  • Using the board manager (Tools -> Board: ... -> Board Manager ...), install or update the "Arduino megaAVR boards" package. Version 1.6.24 or later is required.
  • Launch the hourly IDE release and use the IDE's library manager (Sketch -> Include Library -> Manage Libraries ...) to install/update the following libraries: WiFiNINA, ArduinoBLE. Version 1.3.0 or later of the WiFiNINA library is required.
  • Plug in the Uno WiFi Rev2 board into your PC with a USB cable.
  • Select Arduino Uno WiFi Rev2 as the board and it's serial port in the Tools menu of the IDE.
  • Open the WiFiNINA Firmware Updater example sketch: File -> Examples -> WiFiNINA -> Tools -> FirmwareUpdater
  • Upload the sketch onto your board.
  • If the Serial Monitor is open, close it.
  • Launch the "WiFi 101 / NINA Firmware Updater" from the Tools menu of the IDE
  • Select the Serial Port for your board. The latest version of firmware for the NINA will be automattically selected.
  • Click the "Update Firmware" button, and wait for the update to complete.
  • Close the Updater.
  • You can check the version of firmware loaded on the NINA using the Check Version example of the WiFiNINA library: File -> Examples -> WiFiNINA -> Tools -> CheckVersion example sketch.
  • Now you can start using the examples of the ArduinoBLE library
As always we welcome any feedback on the new features here on the forum.
Update: The version 1.2.0 of the NINA firmware had issues with WiFi TLS/SSL connections. We've corrected and deployed a new v1.2.1 firmware in the next hourly build of the IDE.
sm6yvr
Thank you for the guide!
I'm now running firmware version 1.2.1
BR
Roberth Andersson
kock
In step 7, downloading "Firmware Updater tool" seems to be correct.
In step 9, my IDE 1.8.7 proposes "WiFi 101 Firmware Updater" and not "WiFi 101 / NINA Firmware Updater"
In step 10, i click "test connection" => i got "connection error ... Programmer not responding"
In step 11, i got "Programmer not responding"
my configuration is :
- IDE 1.87
- installed firmware is 1.0.0 (info from check tool).
Thanks for your help
Dan
sandeepmistry
Hi @kock,
From step 1) you should be using the hourly IDE build and not version 1.8.7. Today IDE v1.8.8 has also been released which also contains the new firmware updater for the NINA module.
sunbro42
Hi @sandeepmistry
When using CheckFirmwareVersion the sketch still indicates version 1.2.0 to be the latest version (using Arduino IDE 1.8.8, WiFiNINA library version 1.3.0 and Arduino UNO WiFi REV2):
Code: [Select]
WiFiNINA firmware check.
Firmware version installed: 1.2.1
Latest firmware version available : 1.2.0
Check result: NOT PASSED
 - The firmware version on the module do not match the
   version required by the library, you may experience
   issues or failures.
Also, when I upload SSL certificates to the WiFi module using the WiFi101 / WiFi NINA Firmware/Certificates Updater interface in a sketch where I want to connect to that domain (with FirmwareUpdater uploaded on my Arduino), the communication with the WiFi module always fails, no matter what domain. I have to unplug the Arduino for the module to work again, but then I can't connect to secure sites.
Any help on this would be greatly appreciated!
kock
Thanks for your support. After updating my IDE 1.8.7 to IDE portable 1.8.8 on Windows XP, i'm now running firmware version 1.2.1.
Concerning the future, how will we be informed a new firmware is available ?
Happy new year.
dan
jraggas
Hi Sandeep,
I was able to go through all of your steps to install the firmware with BLE support.
I was able to upload the example ArduinoBLE - LED.
I then unplugged my Arduino from the computer and plugged it into a different power source.
I then went to connect to the Bluetooth from my computer, where I was able to see a bluetooth device named "LED". However I am not able to connect to the device in order to send data and turn on the LED.
Have I missed a step , or can you give any help?
Thank you
TimEllis
When I open the WiFi 101 / NINA Firmware Updater the window that opens is very small so that I cannot read everything.  How can I make this larger?
With the default f/w winc1501 selected I get an error while reading flash memory.  If I choose NINA 101 I got things to download.  But after that I cannot get the programmer to work if I press the test programmer button.
HELP!
TimEllis
I was able to get the programmer working again.  I updated my F/W to 1.2.1 but when I run the CheckFirmwareVersion I get:
Communication with WiFi module failed!
My UNO WIFI rev2 used to work with the client and server examples and now all of those also fail with the same Communication with WiFi module failed!
How can I go back to the version of F/W that came with the board?
tjpk
Hi, I'm new here and just started my adventure with Arduino, but actually I'm having similar problem as TimEllis, communication fails after several minutes. It might be 3 or even 150. Pls advise.
jcj99
do you mean i cant include wifinina and ble on compile? or just that i cant run wifi functions and ble at the same time? i would like to switch between BLE and wifi in the same program
DryRun
Could you please edit the Overview of the product page and mention BLE somewhere, as it can mislead a lot of people into thinking that this board only has WiFi support and no BLE. :)
stlentz
I am trying to update the firmware on a MKR4000 board using IDE 1.8.10 Under Mac OS 10.14.6.
When I go to Tools: WiFi 101 / WiFiNINA Firmware/Certificates Updater, the options available are NINA firmware 1.1.0 and 1.0.0.
I believe all my libraries are up to date, at least I'm not being nagged to update them.
Everything works fine, the upgrade process runs as it should, but how do I get firmware version 1.2.1 onto my computer so the IDE can download it to the board?
