Hello,
first of all thank you very much for your help!
Unfortunately I am physicist, that's why I do have to google your abbreviations and ideas before I am able to evaluate your approach.
@ard_newbie: Thank you for the idea to use a "normal" microcrontroller. I recently found a project like that using an Arduino Nano:
https://github.com/chimmymew/MCA. However I ordered a "DUE" to give it a try (because of the DMA, which should make the difference to a Nano?).
@limba & DarioPennisi: As far as I understood, I am running into troubles if I do not find a way to transfer all the data an ADC samples. That's why I do have to use LVDS (low voltage differential signaling), that can send at about 200MBit/s. The FPGA at the Vidor4000 itself seems to be capable to do this job, but there is no way to connect an external ADC (that has high-grade properties) to receive the data that has to be analyzed.
I have ordered an other FPGA at Ebay in parallel (
https://www.ebay.de/itm/272547446602), since I do not have any experience with these high-speed-applications mikrocontrollers are not able to deal with.
Are there instructions to the world of FPGA you would recommend for someone starting with these devices and who would try to do a multichannel-analysator with PHA?
Thank you for your help!!
