Topic: Impossible to set an initial position for my Servo  (Read 285 times) previous topic - next topic
zerhorace
Hi !
I'm a bit lost ... After reading and applying a lot of answers from the forum, it's still impossible to set an initial position for my servo : Servo PDI 6225MG 300 (it can rotate up to 295°)
This Servo works fine, I've used it for lots of projects but I can't set an initial position, at the start the Servo doesn't want to move.
Do you have any idea why ?
Code: [Select]
#include <Servo.h>
int val = 0;
int pot;
Servo moteur;
int bouton;
  moteur.write(100);
  moteur.attach(9);
  pinMode(2, INPUT);
slipstick
That technique works with all the servos I've tried. Does the servo go to the correct position if you do the write(100) immediately AFTER the attach(9)?
Perhaps it's a power or wiring problem. That servo looks like it will need a lot of initial current to get it to start moving, so it mustn't be powered from the Arduino 5V and it should not be connected through a breadboard.
Steve
zerhorace
Like that ?
Code: [Select]
#include <Servo.h>
int val = 0;
int pot;
Servo moteur;
int bouton;
  moteur.attach(9);
  moteur.write(100);
  pinMode(2, INPUT);
outsider
You did your setup() function backward from the way @slipstick showed you, look again:
Code: [Select]
  moteur.write(100);
  moteur.attach(9);
  pinMode(2, INPUT);
Do you have a pulldown resistor (10k) on pin 2? Where is servo power coming from?
