Topic: New OSHW logo (Read 5079 times) previous topic - next topic
graynomad
I see the open hardware summit vote has come in with the favourite logo (see attached).
There are three issue it seems…
Kerning: the space after the two Rs should be tightened (so I'll just do that myself)
PCB: the text won't work on a PCB, I suggest dropping it and just using the graphic. (I haven't tried this yet but assume it would work)
Two colours: Classic error from the days of fax machines, so fill with the outline colour or leave clear and just have the outline.
Overall is seem to be well received, does anyone plan to use it?
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Valalvax
Sure, if I ever do anything that it would be needed/work
The R's just look funny period...
liuzengqiang
I would use several complete gears with different colors and locked together maybe even cast the world map (2-color) onto the gears or use small gears to fill up a world map to represent world-community.
This only seems to me like a broken piece of hardware. I know it represents my skill level but I just don't want to admit. :smiley-mr-green:
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
Valalvax
Looking at it, the opening is in the shape of a keyhole, I may be looking too hard into it though...
graynomad
Quote
But people can get used to anything. After all, a popular open-source operating system uses a goofy flightless bird as its symbol/mascot.
Yep, you can argue for years about the ideal logo, but once anything is agreed upon and used it becomes obvious and recognizable.
Quote
he he, I can relate to that.
______
Rob
westfw
Quote
That's what I did for my EAGLE implementation.
EMSL has some larger versions for gEDA that include the text, and it looks pretty good.
Thread with a bunch of implementation pointers here:
http://www.openhardwaresummit.org/forum/viewtopic.php?f=5&t=421
mowcius
westfw, forgive my eagle eye (no pun intended) but that EAGLE version looks a bit off. Not saying I can do any better but the opening doesn't quite look large enough and the gear teeth look a bit too square.
Perhaps people would disagree with me there.
logic
Nope, you're seeing a keyhole. Compare to the Open Source Initiative logo:
And see the OSI FAQ, fifth question down. :)
-Ed
Felix qui potuit rerum cognoscere causas.
westfw
Quote
Yeah;  Grumble Grumble artists don't provide polar-coordinate based parametric equations for their work...
It should be easily adjustable; let me know if you come up with better parameters.
mowcius
Quote
Now... is there any more info on the construction of that logo?
logic
Beyond the FAQ on OSI's website, I don't think so; there's a long history of mentions regarding the logo in the board meeting minutes, but I wasn't able to find anything that talked about what the criteria for the original logo were, or how they went about selecting it.
-Ed
westfw
Quote
There was call for submissions, an executive narrowing of the field from 100+ entries to 10 finalists, and a popular vote.
http://www.openhardwaresummit.org/oshw-logo-v1-0/
logic
I know about the selection of the OSHW logo (I've been following it since the final open hardware definition was announced); I think mowcius was asking about the OSI logo I posted above. :)
-Ed
mowcius
Because the OSH logo is similar to the OSI logo, it was kinda a comment for westfw as he mentioned there were no equations for the OSH logo - perhaps there is some info somewhere about the geometric construction of the OSI logo (it would help with getting the keyhole spot on in calculation.
48X24X48X
Hi Guys,
Does anyone have a higher resolution of the logo in jpg/png/bmp? Something like 300x300 dpi at least.
In Diptrace when I reduce the silkscreen recognizability to something like 5 mil (should be nearly same as the fab), it looks pretty bad and all the edges became rounded. I have tried using other format and convert them to images, the result is pretty much the same. :(
