Topic: Yun not showing in IDE (when other Yuns Do) (Read 701 times) previous topic - next topic
myjunkmalebox
I have 4 Yuns in my house controlling LEDs.  2 originals and 2 brand new REV2s.
All four are configured the same way in my router with static IPs.  All have unique names on the network, ArduinoX (1 - 4).  Three of them show up in the IDE (1.8.7) one does not.  The odd one is accessible via IP, and is running my sketch and talking to the other Yuns as it should (they sync modes).  Everything seems totally fine with it, except it won't show up in the IDE which makes sketch updates annoying.
pert
By "it won't show up in the IDE", do you mean that no port appears in the Arduino IDE's Tools > Port menu when you plug it into the computer using the USB cable?
myjunkmalebox
If it's plugged in via cable it shows up.   I does not show up under the network ports with the other 3.
ballscrewbob
Do they all have the same firmware ?
Do they all use the same network settings (sounds like you may have a setting incorrect) ?
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
myjunkmalebox
The two pairs are on different firmware, old pair and new pair.  But each pair is on the same.
As far as I can tell they all have the same network settings on the device, and they are all definitely the same on my router.
ballscrewbob
Some (not all) routers group IP's.
EG. all Lan might be 192.168.0.2 to 100 and WiFi into 192.168.0.101 to 200 etc (example only)
Might be worth checking for.
Some Routers also accept or change a connection to IPV6 over IPV4.
I have some devices that show under both protocol.
No I dont understand why they work that way but they seem happy until I try call them up by an IP at which point I occasionally run into issues.
Just something else to keep an eye on.
myjunkmalebox
All 4 devices are set to always receive the same IPv4 IP.  So it's not an IPv6 issue or an odd IP.
