Topic: Noob Question : L298N Controller Board Motor Input Error (Read 209 times) previous topic - next topic
SighBorg121
Nov 22, 2018, 03:23 pm Last Edit: Nov 22, 2018, 03:28 pm by SighBorg121
Tried checking inputs of motor b i.e In 3 and 4 with a 9v battery supply but it didnt work....even followed the datasheet and all that but cant make any sense...
And yes i ve made the connections properly connected the battery negative terminal to ground and used a seperate 9v battery to power up the shield...
ThomasFromAmsterdam
For the motor to run, one of the two pins IN3 and IN4 needs to be high, the other low. The PWM signal needs to go to EnB
slipstick
What motor? What type of "9V battery"? The little rectangular things usually can't supply enough power to run motors. Oh and what do "didn't work" and "cant make any sense" mean, in detail?
If you provide the code you're using and a circuit diagram then we can verify whether you've really connected things properly and you're trying to drive them properly.
Steve
SighBorg121
Yes i did just that....
Steve
Rectangular 9v battery  which was used to check whether inputs are working by sending the current/voltage.. There was no code involved... I was just checking if they work correctly or not... Cant make any sense means that they are not responding to voltage applied to the input
