Topic: How to code for dry contact open/close not in loop (Read 637 times) previous topic - next topic
MKSaeed
I have a dry contact switch want to use it as door sensor if door open then send "open" in serial one time
I tried this code but it gives me open in loop! how can I make it one time when switch on or door opened
Code: [Select]
byte Switch = 2;
  pinMode(Switch, INPUT);
  if (digitalRead(Switch) == HIGH) {
    Serial.println("Open");
    delay(10);
  else {
        Serial.println("Close");
Thanks for all
MKSaeed
Grumpy_Mike
How is the switch wired?
Your code assumes you have an external pull down resistor?
Is it connected correctly.
The best way to wire a switch is between input pin and ground. Then use INPUT_PULLUP in the pinMode call and look for == LOW in the if statement.
MKSaeed
#4
Nov 23, 2018, 11:35 am Last Edit: Nov 23, 2018, 11:44 am by MKSaeed
@Grumpy_Mike
I have resistor (brown-red-black) connected with ground!
Is it correct the resistor value?
I checked my resistor value from this site : https://www.digikey.com/en/resources/conversion-calculators/conversion-calculator-resistor-color-code-4-band
and found it is 15 ohm!
I think need 10K ohm right?
Grumpy_Mike
#5
Nov 23, 2018, 03:18 pm Last Edit: Nov 23, 2018, 03:19 pm by Grumpy_Mike
Quote
Yes but that would not matter if that was the only fault. Sure it would draw 0.3 mA when the button was pressed but it would still read a zero. Anyway try it and see.
Quote
That is connected from the input pin to ground, with the switch connected to the input and +5V.
Those colours would be a 12 Ohm resistor.
Is this a four pin push button? If so you should wire the button across the diagonal because pairs of contacts are connected together.
MKSaeed
Yes I have 4 pins button and connected diagonal as you said.
I want when I press the button write with serial "open" one time and when release the button write "close" one time.
with this code I got it but I have contentious  open and close like loop
Code: [Select]
byte Switch = 2;
    delay(10);
  else {
Grumpy_Mike
Code: [Select]
    delay(10);
    while( digitalRead(Switch) == HIGH) { } // do nothing until low
  else {
       while( digitalRead(Switch) == LOW) { } // do nothing until high
MKSaeed
I did this code and when button is released open message is in loop but when I press the button the "close" message keep no loop
how can I made "open" message not to show in loop...I mean when button release then the "open" message shows one time?
Code: [Select]
int Switch = 2;
int buttonState;         // current state of the button
int lastButtonState = 1;     // previous state of the button
    buttonState = digitalRead(Switch);
  if (digitalRead(Switch) == LOW && buttonState == lastButtonState) {
    delay(100);
  if (digitalRead(Switch) == HIGH && buttonState != lastButtonState){
 lastButtonState = buttonState;
Grumpy_Mike
Do not include the last button state in the if statement but a Boolean variable that is set to the state of the door.
MKSaeed
@ Grumpy_Mike thanks for reply friend
any example can explain how to do it?
MKSaeed
#11
Nov 23, 2018, 05:51 pm Last Edit: Nov 23, 2018, 05:54 pm by MKSaeed
[/quote]
Code: [Select]
    delay(10);
  else {
I tried it and gave me this output :
Open
Close
Open
Close
MKSaeed
outsider
#14
Nov 23, 2018, 06:36 pm Last Edit: Nov 23, 2018, 06:37 pm by outsider
Why not do as GMike said in reply #3, you won't need a resistor.
