Okay let me try what your explaining me.
I don't know if posting my code will work out better so you can understand it.
With this code I can read the first line and print it to the serial monitor.
Thanks for your help.
File file;
initializeSD();
openFile("1hour.txt");
Serial.println(readLine());
closeFile();
void initializeSD()
Serial.println("Iniciando SD...");
if(!SD.begin(4)){
Serial.println("No se puedo iniciar");
return;
void closeFile()
if (file)
file.close();
Serial.println("File closed");
//metodo que abre el archivo
int openFile(char filename[])
file = SD.open(filename);
if (file)
//Serial.println("File opened with success!");
return 1;
} else
Serial.println("Error opening file...");
return 0;
String readLine()
String received = "";
char caracter;
while (file.available())
caracter = file.read();
if (caracter == '\n')
return String(received);
received += caracter;
return "";
