Topic: Dropping 12V to 5V using voltage regulator(s) (Read 2155 times) previous topic - next topic
BabyGeezer
Looking at the datasheet of the 78XX voltage regulators re 'power dissipation', it is clear that dropping from 12V to 5V - and drawing 1A is too much.
i have a 12V DC adaptor, can i then use a 7809 *and* a 7805 to drop the voltage over two 'regulators' - ie. dropping from 12V to 9V and then subsequently to 5V.
lousy efficiency aside, is this setup workable ?
i just want to test a circuit at minimal requirement of 1A but the only wall-wart i have that can supply 1000mA is a 12V one.
i don't intend to make it a fixed/permanent scenario.
on a related issue, if i were to purchase a DC-DC buck converter (lots of them on eBay based on the LM2596) - what would the 'current' situation be, meaning, are buck converters able to supply the full current coming in from the high voltage side ?
ie. 12V in at 1A, will come out at the lower voltage, but also at 1A.
Attach your images to be viewed directly - THIS WAY;
https://forum.arduino.cc/index.php?topic=519037.0
MarkT
#1
Dec 07, 2018, 02:35 pm Last Edit: Dec 07, 2018, 02:37 pm by MarkT
7805 will handle 1A at 12V input fine, so long as you use a big enough heatsink.
You'll need heatsinks anyway as 7W is too much for two bare TO220 packages.  1W per
package (without heatsink) is pushing it, use heatsink!
But you'll be better off using a cheap switch-mode DC-DC converter like the eBay LM2596 units,
much higher efficiency, no heatsink needed (only downside is the noise which could be an issue
with sensitive low-voltage analog signals).
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
BabyGeezer
i see, looks like i still can't do the test yet then, no heatsinks yet.
just to be sure though, from the datasheet;
it says Maximum Power Dissipation is PD=(TJ(max)- TA) / *0JA (*0 is actually theta)
that becomes PD=(150-33)/19 = 6.16W
so; it won't handle 7W, right ?
okay, looks like i'll be going with that option - how about the current, those converters will pass the input supply current through with no losses ?
Deva_Rishi
You could  put 2 7805's parallel, guess you still need a heatsink, though a fairsize piece of Alu would do the trick the 7805's will tell you if it's okay, they have automatic shut down for over-current and over-heat.
To 'Correct' you have to be Correct. (and not be condescending..)
PerryBebbington
Okay, looks like i'll be going with that option - how about the current, those converters will pass the input supply current through with no losses ?
It doesn't work like that. The short answer is don't worry, it will do what you need.
A DC DC converter swaps current for voltage. If you feed 12V in and take 5V out at 1A then the input current at 12V will be a lot less. If there were no losses then the input current at 12V for 5V 1A out would be 5/12 * 1 = 0.42A (This is where some kind person tells me I got the maths wrong!) However, they are not perfect, they do waste some power so I would assume that for 1A out at 5V then 0.5A in at 12V would be needed.
Just connect it up, it will be OK.
Deva_Rishi
No.. you got the math right !
BabyGeezer
#6
Dec 07, 2018, 05:17 pm Last Edit: Dec 07, 2018, 05:17 pm by BabyGeezer
...the 7805's will tell you if it's okay, they have automatic shut down for over-current and over-heat.
i see, good to know !
Thanks, that puts my mind at ease :)
i see - i kinda figured that the power (wattage) is the limiting factor.
conversely, with a boost converter, we can then expect a *drop* in the current ?
(eg. from a 5V@1A supply, we won't get 1A if we boost it to 9V)
okay - i shall proceed with confidence !
Deva_Rishi
Just to be clear a 7805 is not a converter like Perry is suggesting but a regulator, which drops voltage leaving current the same and dissipating the extra energy as heat, not very energy-efficient of course.
Smajdalf
You may use a resistor to drop the excess voltage. Or a few diodes. Use the linear regulator as the last step.
PerryBebbington
I see - I kinda figured that the power (wattage) is the limiting factor.
Conversely, with a boost converter, we can then expect a *drop* in the current ?
Okay - i shall proceed with confidence !
Power is a limiting factor, read the data sheet for the DC DC converter. However, for what you have described, I don't think you will have a problem as long as the converter you are using is rated to supply at least 1A. If a DC DC converter were 100% efficient (obviously they are not) then the input power would equal the output power, so Vin * Iin would equal Vout * Iout.
Yes, if you use a boost converter then the output current will be lower than the input current.
(I'd better hide in case it goes BANG!)
MarkT
#10
Dec 07, 2018, 08:56 pm Last Edit: Dec 07, 2018, 08:57 pm by MarkT
That's using a PCB as heatsink or nothing as heatsink, using a block of copper that 19 becomes 3, and the power handling is  30W for
a 90 deg rise above ambient.  Personally I'd not recommend trying to more than 20W out of a TO220 package
as you have to allow for the heatsink itself and any thermal pad or grease.
Paul__B
Perhaps cut up a couple of aluminium cans, open them out and arrange three or four layers together with a hole through them, use a washer to hold them together where you screw them to the tab of the 7805.  The separate layers can fan out as fins on the heatsink.
Wawa
Stop fiddling with linear regulators, and buy a switching (buck) converter.
Don't you have a car cigarette lighter style USB charger (same thing).
Leo..
BabyGeezer
yes, thanks for confirming this - it's what i had in mind with my rudimentary knowledge of electronics.
ahh, good tips - thanks !!
obviously they should be properly rated, my stock of resistors are just the 1/4W ones though, but i do have a few rectifier diodes to line up in series.
ok, good - thanks !!
i think... :-P
ahh, i see - that's very handy to know - the datasheet wasn't very informative on that, it didn't even mention heatsinks at all which was strange - although i can't say what's normal, i think i've seen *a* datasheet which gave specs with heatsink usage advice but i don't know if that's the norm.
Thank you, very handy tip !!
yes sir - just purchased and on the way !
Leo..
oh - you mean like phone chargers that plug into the mains AC ?
yeah - those supply 5V don't they (usually at 1A) - now, there's a thought...
Thanks again everyone for such informative tips.
Wawa
No, I meant a USB phone charger that plugs into the cigarette lighter hole in the dashboard of a car.
You just asked for a 12>5volt/1A regulator.
A 5volt/1A phone/tablet USB supply is ofcourse an easy way to get 5volt/1A.
Leo..
