Topic: Read 4 bytes from arduino with C code (Read 355 times) previous topic - next topic
thymbahutymba
Dec 07, 2018, 04:56 pm Last Edit: Dec 07, 2018, 04:57 pm by thymbahutymba
I'm tring to read data from arduino with simple C code without success.
The code is the following:
Code: [Select]
    uint8_t one[4] = {1, 2, 3, 4};
    int writed = Serial.write(one, 4);
Code: [Select]
#include <fcntl.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <termios.h>
#include <time.h>
#include <unistd.h>
int main() {
    int port = open("/dev/ttyACM0", O_RDONLY | O_NOCTTY);
    uint8_t buffer[4];
    int n_read;
    uint32_t tt;
    struct termios options;
    tcgetattr(port, &options);
    cfsetispeed(&options, B9600);
    cfsetospeed(&options, B9600);
    options.c_cflag &= ~PARENB;        // cleare parity bit;
    options.c_cflag &= ~CSTOPB;        // set stop bit = 1;
    options.c_cflag &= ~CSIZE;         //
    options.c_cflag |= CS8;            // set data bit to 8
    options.c_cflag &= ~CRTSCTS;       // no hardware flow control
    options.c_cflag |= CLOCAL | CREAD; // enable receiver ignore status lines
    options.c_cc[VMIN] = 4;            // wait for 4 bytes
    options.c_cc[VTIME] = 0; // no minimum time to wait before read returs
    tcsetattr(port, TCSANOW, &options); // commit the options
    // flush serial buffer
    tcflush(port, TCIFLUSH);
    while (1) {
        n_read = read(port, buffer, 4);
        printf("%i %i\n", n_read, buffer[0]);
        sleep(1);
What i get is always 0 bytes read, how i can fix this?
matcanyn
the function "Serial.write" will just write the data as binary. If you wanna see it on serial monitor you should use "print" instead.
    for(uint8_t i=0; i<sizeof(one)/sizeof(uint8_t); i++){
    Serial.print(one);
thymbahutymba
As you see in previous post i want read bits from C code that didn't works as I expected
Coding Badly
Code: [Select]
...is not the correct way to set a bit.
Coding Badly
Code: [Select]
Your claim does not match the comments.  There is no exit path for anything less than four bytes.
thymbahutymba
#5
Dec 07, 2018, 10:41 pm Last Edit: Dec 07, 2018, 10:43 pm by thymbahutymba
if you see the code into arduino i want to send exactly 4 bytes and will be always thus
Code: [Select]
I followed some examples online, if you know what's wrong, tell me and I'll fix it and hope it works
Coding Badly
Yup.
Reread my post.  Try to put more thought and care into the effort.
westfw
I don't see anything in your C code to set "raw" mode, so that side may be sitting there waiting for a line terminator...
As an experiment, try "stty raw; ./myprog; stty cooked"
(that's what I usually do when I need a quick C program to read data from a microcontroller.  Looking up all the (varied) tcsetattr/ioctl stuff is too much work...
(also:  "stty raw; ./myprog </dev/tty.ACM0; stty cooked" saves even more work!)
thymbahutymba
Yup.
I don't understand what you mean. Could you suggest me how i can fix it?
I need that everythings works with only C code, so i have to read four bytes from arduino that in this case contains 1, 2, 3, 4.
westfw
