Topic: Variable or field declared void (Read 1 time) previous topic - next topic
dwyerl2
I am having trouble trying to figure this error out. Thanks for any help in advance.
Arduino: 1.8.7 (Windows 8.1), Board: "Arduino/Genuino Uno"
C:\Users\dwyerlog\Documents\Arduino\Seed_Cleaner\Seedcleaner6.0\Seedcleaner6.0.ino: In function 'void infeedauger1()':
Seedcleaner6.0:75:6: error: variable or field 'outfeedauger' declared void
 void outfeedauger
Seedcleaner6.0:78:54: error: expected '}' before ';' token
   outfeeduplimitState = digitalRead(ulimitoutfeedPin);
Seedcleaner6.0:105:1: error: expected '}' at end of input
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
const int ulimitinfeedPin = 13;
const int llimitinfeedPin = 12;
const int infeedaugerPin = 9;
const int infeedHopperFullStatePin = 5;
int infeedfaultsignal = 3;
bool infeeduplimitState ;
bool infeedlowlimitState ;
bool infeedfaultSignal = LOW;
bool infeedauger = LOW;
bool infeedHopperFullState = LOW;
const int ulimitoutfeedPin = 11;
const int llimitoutfeedPin = 10;
const int outfeedaugerPin = 8;
const int outfeedHopperFullStatePin = 4;
int outfeedfaultsignal = 2;
bool outfeeduplimitState ;
bool outfeedlowlimitState ;
bool outfeedfaultSignal = LOW;
bool outfeedauger = LOW;
bool outfeedHopperFullState = LOW;
  pinMode( ulimitinfeedPin, INPUT);
  pinMode(infeedaugerPin, OUTPUT);
  pinMode (llimitinfeedPin, INPUT);
  pinMode (infeedHopperFullStatePin, OUTPUT);
  pinMode (infeedfaultsignal, OUTPUT);
  pinMode( ulimitoutfeedPin, INPUT);
  pinMode(outfeedaugerPin, OUTPUT);
  pinMode (llimitoutfeedPin, INPUT);
  pinMode (outfeedHopperFullStatePin, OUTPUT);
  pinMode (outfeedfaultsignal, OUTPUT);
void infeedauger1 (){
  //read both limits at the start of the loop, then use the Status to do your control. ie, you take a snapshot of you project inputs.
  infeeduplimitState = digitalRead(ulimitinfeedPin);
  infeedlowlimitState = digitalRead(llimitinfeedPin);
  digitalWrite(infeedaugerPin, infeedauger);
 if (infeeduplimitState == LOW && infeedlowlimitState == LOW) //hopper is full.
    infeedauger = LOW;
    infeedHopperFullState = HIGH;
  if (infeeduplimitState == HIGH && infeedlowlimitState == HIGH) //Hopper is empty.
    infeedauger = HIGH;
  if (infeeduplimitState == HIGH && infeedlowlimitState == LOW & infeedHopperFullState == LOW) //Hopper is filling
    infeedauger = HIGH;
  if (infeeduplimitState == LOW && infeedlowlimitState == HIGH)  //not a possible combination when operating correctly.
    infeedauger = LOW;
    infeedfaultSignal = HIGH;
void outfeedauger
  outfeedlowlimitState = digitalRead(llimitoutfeedPin);
  digitalWrite(outfeedaugerPin, outfeedauger);
  if (outfeeduplimitState == LOW && outfeedlowlimitState == LOW) //hopper is full.
    outfeedauger = LOW;
    outfeedHopperFullState = HIGH;
  if (outfeeduplimitState == HIGH && outfeedlowlimitState == HIGH) //Hopper is empty.
    outfeedauger = HIGH;
  if (outfeeduplimitState == HIGH && outfeedlowlimitState == LOW & outfeedHopperFullState == LOW) //Hopper is filling
  if (outfeeduplimitState == LOW && outfeedlowlimitState == HIGH)  //not a possible combination when operating correctly.
    outfeedauger = LOW;
    outfeedfaultSignal = HIGH;
larryd
#1
Dec 09, 2018, 10:53 pm Last Edit: Dec 09, 2018, 10:53 pm by larryd
void outfeedauger
Is this the proper format for a function?
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
slipstick
Your brackets {} are in a mess. Try using Auto Format (Ctrl+T) and you should see the problems.
Also even when you get the brackets sorted out "void outfeedauger {" is invalid.
Steve
Deva_Rishi
this line although it compiles and it is technically speaking incorrect and will not cause any strange behavior is disturbing to me
To 'Correct' you have to be Correct. (and not be condescending..)
dwyerl2
I changed it to void outfeedauger1(){ and I still get an error but I donot get one on void infeedauger1(){
 I auto formatted and I am still getting these errors.
Seedcleaner6.0:75:29: error: a function-definition is not allowed here before '{' token
       void outfeedauger1 () {
Seedcleaner6.0:105:9: error: expected '}' at end of input
exit status 1
void infeedauger1 () {
    infeedauger = LOW;
      infeedauger = HIGH;
        infeedauger = HIGH;
          infeedauger = LOW;
            outfeedauger = LOW;
            outfeedauger = LOW;
outsider
Shouldn't line 80 be a " } " instead of " { " ?
saximus
The curly braces are still a giant mess. You probably need to go through it, group by group, to work out what you're trying to keep together and why.
You're also doing nothing in the loop at the moment. Is that deliberate or is it a symptom of the seemingly random curly bracket locations?
