I've encountered a problem in Section 5.2 Open loop control of Rover:
When I "Deploy to Hardware" and then run the rover on the floor it first does a turn to the left and then a straight line motion. I opened the v and w Signal Builders and they are as described in the instructions, so it should go straight and then turn left. So then I made a change in each of the two signal graphs and reDeployed to Hardware. The changes I made in the v signal showed up in the w behavior and vice versa.My knowledge of matrix algebra is slight so I cannot check the correctness of the matrix expression inside the "convertToWheelVel" subsystem but other than that I don't know where to look for the source of the problem. Can anyone offer some help, please.
