Topic: I Need Help With My Code (Read 221 times) previous topic - next topic
SetSuko
This Is A Code I Grabbed From A Tutorial Online And I Have Trouble With It.
when i want to upload the code to my arduino uno it says
expected primary-expression before 'int'
i included a comment where i have that problem, can someone fix it for me?
i am not that good of a programmer and i am new to arduino
Using an Arduino with a 120v Relay
Parts used:
--ultrasonic sensor
--desk lamp
--120v relay
--desk lighting
This sketch uses an ultrasonic sensor to detect whether
a person in near or sitting near a desk, and sends a
signal to a 120V relay to turn desk lighting on or off.
#include <NewPing.h>
const int LIGHT = 10;
const int TRIGGER = 12;
const int ECHO = 11;
NewPing sonar(TRIGGER, ECHO);
void setup(){
  pinMode(LIGHT, OUTPUT);
/* The main loop iterates every 2.5 seconds. */
void loop(){
  /*In order to get a accurate measure of wether
  someone is near, we read the ultrasonic sensor
  30 times and take the average. That way, if the
  ultrasonic sensor reads sporadically as it
  occasionaly does, those values will be averaged out.
  This takes 0.05 * 30 = 1.5 seconds to get a value
  from the sensor. */
  while (int i, i < 30, i++){                                     //!!!!!!!!!!THIS LINE IS MY PROBLEM!!!!!!!!!!
    sum = sum + sonar.ping_cm();
    delay(50);
  int average_distance = sum/30;
  /* Using the value, we send a signal to the relay
  depending on whether someone is detected less than
  130 cm away. We also pause for a second for good
  measure. */
  if (average_distance < 130){
    digitalWrite(LIGHT, HIGH);
  else{
    digitalWrite(LIGHT, LOW);
PaulS
This is nowhere near the correct format for a while statement.
It looks like you tried to use the syntax for a for loop, but changed the semicolons to commas. Look up what a while statement is supposed to look like.
terryking228
Hi, Something missing here:
think you need:
while (int i=0; i < 30; i++){
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
UKHeliBob
In view of the problems with it I would be interested in a link to where you got it from.
PaulS
think you need
And I think YOU need to RTFM, too.
SetSuko
#5
Dec 10, 2018, 07:50 pm Last Edit: Dec 10, 2018, 07:51 pm by SetSuko
think you need:
now it says "expected ')' before ';' token" at that same line in my code
AWOL
think you need:
That's syntax for a for loop, not a while.
Perehama
#7
Dec 10, 2018, 08:07 pm Last Edit: Dec 10, 2018, 08:08 pm by Perehama
int i = 0;
do {
    delay(50);
   } while (++i < 30);
The slender snake hissed as she slithered slowly over the rocks, grass and leaves.
