Topic: Problem of using Bluetooth module and Ultrasonic sensors (Read 901 times) previous topic - next topic
Ammar-Safwat
Dec 14, 2018, 05:01 pm Last Edit: Dec 14, 2018, 05:05 pm by Ammar-Safwat
I have a problem with my project that is 4 wheels car interfaced by android application through a bluetooth module and contains an ultrasonic sensor for obstacles avoiding .. the problem is there is lagging between sending orders from the application and the car movement for a few seconds
this is the code that i've used :
int IN1=3;
int IN2=4;
int IN3=7;
int IN4=8;
int ENA=5;
int ENB=6;
int ABS=135;
//HC-SR04 Sensor connection
const int trigger = 11;
const int echo = 12;
float distance;
unsigned long period;
void Forward (){
 digitalWrite (ENA,HIGH);
 digitalWrite (ENB,HIGH);
 digitalWrite (IN1,LOW);
 digitalWrite (IN2,HIGH);
 digitalWrite (IN3,LOW);
 digitalWrite (IN4,HIGH);
void Backward () {
 digitalWrite (IN1,HIGH);
 digitalWrite (IN2,LOW);
 digitalWrite (IN3,HIGH);
 digitalWrite (IN4,LOW);
void Stop (){
 digitalWrite (ENA,LOW);
 digitalWrite (ENB,LOW);
void Right () {
  analogWrite(ENA,ABS);
  analogWrite(ENB,ABS);
  digitalWrite(IN1,HIGH);
  digitalWrite(IN2,LOW);
  digitalWrite(IN3,LOW);
  digitalWrite(IN4,HIGH);
void Left (){
  digitalWrite(IN1,LOW);
  digitalWrite(IN2,HIGH);
  digitalWrite(IN3,HIGH);
  digitalWrite(IN4,LOW);
void bluetooth_motion() {
  byte Dir = Serial.read();
      if (Dir=='1'){
      Forward();
      Serial.println("FORWARD");
      else if (Dir=='2'){
      Backward();
      Serial.println("BACKWARD");
      else if (Dir=='0'){
      Stop();
      Serial.println("STOP");
      else if (Dir=='4'){
      Right();
      Serial.println("RIGHT");
      else if (Dir=='3'){
      Left();
      Serial.println("LEFT");
 pinMode (ENA,OUTPUT);
 pinMode (ENB,OUTPUT);
 pinMode (IN1,OUTPUT);
 pinMode (IN2,OUTPUT);
 pinMode (IN3,OUTPUT);
 pinMode (IN4,OUTPUT);
 pinMode(trigger, OUTPUT);
 pinMode(echo, INPUT);
  digitalWrite(trigger,LOW);
  delayMicroseconds(3);
  digitalWrite(trigger,HIGH);
  period=pulseIn(echo,HIGH);
  //distance=(period/(2*10^6))*(340*100)
  distance = float(period)/58.8;
  Serial.println(distance);
  delay(3);
if (Serial.available()>0) {
  bluetooth_motion();
if  (distance <= 20) {
  Stop();
Railroader
I have only a brief knowledge about the IDE function "pulseln" so I am guessing telling that there might be a chance of time being spent. How often is that signal being measured coming, what frequency? The code looks like free from whiles and looping around delays. Unless You some kind of chain logic that sums up time I don't see anything pointing out.
Use Your knowledge. If that's not enough, look for education.
Having knowledge, think outside the box to gain more of it. Only trains run like the train, on the rails. The rest run between the rails.
No answers given by PM.
cattledog
pulseIn() is a "blocking function" and there is a timeout period if no echo is sensed. If you comment out the pulseIn(), is there still the lag in response?
If you disconnect the bluetooth and run the program from the serial monitor do you still see the lag in response?
Can you tell us more about the app?
sterretje
Specify the timeout for pulsIn; 10,000 microseconds should give a max distance of approx. 170 cm (just from memory). You can fill it in the formula that you use.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Ammar-Safwat
when i disconnect the bluetooth module and use serial monitor there's no lag it happens only when i connect the bluetooth module
cattledog
This says the problem is not with the code you have written. It's now time to tell us some more about the bluetooth module and the app.
Ammar-Safwat
OK ... the bluetooth module is HC-05 type and the mobile application is Arduino BT joystick and it works with me without any problems when i don't add ultrasonic sensor to it
cattledog
This is what I understand you are indicating for the problem statement.
When using the Serial monitor for command input, (without bluetooth connected) but with the ultrasonic and pulseIn(), the program works for distance measurement and motor control without obvious latency.
When using the Arduino bluetooth joystick app for command input the program works for motor control without obvious latency when the ultrasonic and pulseIn() are not active.
When using the Arduino bluetooth joystick app for command input the program works for motor control with obvious latency when the ultrasonic and pulseIn() are active.
Here's one idea to help narrow down the problem. It will help sort out any possible issue with the joystick app independent of the bluetooth interface.
If you do not use the bluetooth joystick app, but a simple bluetooth serial terminal app to send the commands, do you have the latency?
Can you provide a link to the Android app "Arduino Bluetooth Joystick" you are using.
Ammar-Safwat
i didn't use pulseln() i don't how to use it honstly .. but your conclusion is correct and here is the app :
https://play.google.com/store/apps/details?id=com.heightdev.arduinobtjoysticklite&hl=eng
sterretje
You do use pulseIn ! Read your loop() code line by line.
cattledog
here is the app :
I don't see where the free app has buttons to send text commands, and I'm not going to pay to debug this for you.
Try a different bluetooth serial terminal app.
If you indeed need the joystick, take a look at Joystick Bluetooth Commander which appears to be more widely used, and has a 62 page thread on the forum http://forum.arduino.cc/index.php?topic=173246.915
This may be true, but your code uses the function
