Topic: arduino Nano programming (Read 258 times) previous topic - next topic
32203-0551114-1
can i programme my arduino nano with arduino uno ??i have lost my NANO cable but i have arduino uno and its cable. can i programme my arduino nano by using arduino UNO and its cable?
sterretje
You can program the Nano using the Uno as ISP; I've never done it (I use a programmer) so do a search on the web.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
DrAzzy
#2
Dec 19, 2018, 06:30 pm Last Edit: Dec 19, 2018, 06:30 pm by DrAzzy
Nano cable is standard mini USB (not the now-more-common microUSB - microUSB connectors on bare boards tend to get ripped off during handling - I think they're meant to have a housing around them to prevent that) - they are readily available, often used for cameras and similar. There's a good chance you have one laying around with other spare cables. Using the Uno as a programmer is a really ugly work around for lack of a $1 (a bit more in retail store) cable.
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
Budvar10
There is another solution: remove chip from UNO or block it by shorting RESET and GND (the best with small resistor ~1000ohm) and you can use on-board USB/serial to Nano's Rx & Tx. The RESET signal is little bit a problem. Yo have either to connect Nano's RESET to DTR-RESET on UNO before separating capacitor or do it manually by releasing reset button at right moment at upload start.
However, I have agree with DrAzzy, spare cable should not be a problem... 8)
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
