Topic: Pair HC05 To HC06 and read. Data Logger (Read 652 times) previous topic - next topic
nparafioriti
Hello there,
I have to pair a specific slave module to the master and read the data. The name of the HC06 im working with its on a txt file.
Once paired with the HC05 connected to the Arduino UNO, i have to read the data and save it.
I dont know if i can do all the parametrization at once, or if i have to compile different codes to do this task.
Here is the code example:
Code: [Select]
// BT Data Logger
// BlueTooth Configuration
/* Include the software serial port library */
#include <SoftwareSerial.h>
#include <SPI.h>
#include <SD.h>
#define BT_SERIAL_RX 0 /* to communicate with the Bluetooth module's RXD pin */
#define BT_SERIAL_TX 1 /* to communicate with the Bluetooth module's TXD pin */
#define GREENLED1    3
/* Initialize the software serial port */
SoftwareSerial BTserial(BT_SERIAL_RX, BT_SERIAL_TX);
char c = ' ';
bool succesful = false;
void delayAndRead()
 delay(50);
 while(BTserial.available())
 c = BTserial.read();
 delay(800);
void initHC05ToInq()
    BTserial.println("AT+CMODE=1");// Enable connect to any device
    delayAndRead();
    BTserial.println("AT+ROLE=1");// Set to master in order to enable scanning
    delayAndRead();
    BTserial.println("AT+INQM=1,2,24");//RSSI, Max 2 devices, ~30s
    delayAndRead();
    BTserial.println("AT+CLASS=0");// Disable COD filter
    delayAndRead();
    BTserial.println("AT+INIT");// Init.
    delayAndRead();
string ReadDeviceAddressAndSearch()
 File deviceFile = SD.open("devices.txt", FILE_READ);
 string device="";
 bool deviceAvailable = false;
 while(deviceFile.available())
 device = deviceFile.readStringUntil('\r');
 deviceAvailable = IsDeviceAvailable(device);
 if(deviceAvailable)
 deviceFile.close();
 return device;
bool IsDeviceAvailable(string device)
 static char input[64];
    static uint8_t i;
    char data = '';
 bool result = false;
 while (BTSerial.available > 0)
 BTserial.println("AT+INQ");
 delay(50);
 data = BTSerial.read();
 if ( data != '\r' && data != '\n' && i < sizeof( input ) - 1 )
  input[i++] = data;
  input[i] = '\0';
  i = 0;
  if ( strcmp( input, device ) )
 Serial.println("Device Found");
 result = true;
  result = false;
 if (!result)
 Serial.println("Device not found");
 return result;
 while (!Serial)
 ; // wait for serial port to connect. Needed for native USB port only
 Serial.print("Initializing SD card...");
 if (!SD.begin(4))
 Serial.println("Initialization of SD failed!");
 while (1);
 Serial.println("Initialization Done.");
 // HC-05 default serial speed for AT mode is 38400
    BTserial.begin(38400);
 initHC05ToInq();
 string deviceAddress = ReadDeviceAddressAndSearch();
 if (!succesful)
 if (deviceAddress == "")
 Serial.println("There is no device available to connect...");
 Serial.end();
 BTserial.end();
 initHC05ToInq(); // Try again
 BTserial.println("AT+LINK=" + deviceAddress);// Link to known device
 delayAndRead();
 succesfull = true; //BT configuration ended OK
 //Do Stuff here
 File logFile = SD.open("datalog.txt", FILE_WRITE);
 //BT is ready to communicate to the device
 BTserial.begin(57600);
 // make a string for assembling the data to log:
 char data = "";
 if(BluetoothSerial.available())
 digitalWrite(BUZZER, LOW);
 data = BluetoothSerial.read();
 BluetoothSerial.print(data);
 BluetoothSerial.print("\n");
 // print to the serial port too:
 Serial.println("Value: ");
 Serial.print(data);
 if (logFile)
 logFile.println("Value: ");
 logFile.print(data);
 logFile.close();
 if (data =='1')
 digitalWrite(GREENLED1, HIGH);
 else digitalWrite(GREENLED1, LOW);
 Serial.println("No signal available, data not received");
 digitalWrite(BUZZER, HIGH); //BT not available, not able to retrieve data
