Topic: Pegar IP externo por API (Read 768 times) previous topic - next topic
RenanCastro
Pessoal, estou com dificuldade pra fazer esse código funcionar, preciso pegar um IP externo com essa API, porém ele entra no else.
Code: [Select]
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xA4, 0x28, 0x72, 0xCA, 0x55, 0x2F };
byte ip[] = { 192, 168, 0, 110 };
byte gateway[] = { 192, 168, 0, 1 };
byte subnet[] = { 255, 255, 255, 0 };
EthernetServer server(80);
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.println(F("My ip is: ")); Serial.println(Ethernet.localIP());
  if (client.connect("api.ipify.org", 80)) {
    Serial.println("connected");
    client.println("GET / HTTP/1.0");
    client.println("Host: api.ipify.org");
    client.println();
      Serial.println("connection failed");
Deva_Rishi
thank you Google  !
Quote
Personally, I'm having trouble making this code work , I need to get an external IP with this API, but it goes into the else.
It's Portugese.. don't know the answer to the question, but maybe someone else does.
To 'Correct' you have to be Correct. (and not be condescending..)
bubulindo
Há algo de muito estranho no teu código... porque é que inicias um servidor web quando só precisas dum cliente?
Já experimentaste este exemplo?
https://www.arduino.cc/en/Tutorial/WebClient
E tavez adaptar para o site que queres aceder?
This... is a hobby.
