Topic: Motor/battery dimensioning for a heavy robot (Read 406 times) previous topic - next topic
TheTrueSpaceGoat
Hi everyone !
I am working on a simple robot project : I want to move heavy stuff with a robot.
The characteristics of the robot are :
- Capable of moving 10kg
- A speed of 3 to 5 km/h
- wheel size : 63mm
- 2 motors each driving a wheel
The problem is that I can't find a motor capable of moving a 10kg robot.
I have this engine but I find it too weak for my needs :
https://www.amazon.fr/ChaRLes-Moteur-CHIHAI-enCodeur-couvercle/dp/B07JNJCL5B/ref=sr_1_1?ie=UTF8&qid=1544627721&sr=8-1&keywords=ChaRLes+Moteur+CHIHAI+DC12V+350rpm+enCodeur+moteur+DC+Gear+avec+couvercle
Do you have project that can help me in my research ? Or the ideal engine
Secondly, I have find a 12V Li-po battery, but I use a Dual motor controller and it says it make a voltage drop of about 2V. But I don't know if it's true.
This is my controller :
https://www.amazon.fr/Cytron-bidirectionnel-contr%C3%B4leur-Courant-continu/dp/B07CRG35ML/ref=sr_1_1?m=A17W1QBFCVVCID&s=merchant-items&ie=UTF8&qid=1545303653&sr=1-1
Should I use a 4*3.7V Li-po battery ?
Thank you in advance for your help !
I hope I was clear enough...
jremington
#1
Jan 01, 2019, 12:04 am Last Edit: Jan 01, 2019, 12:07 am by jremington
This site has several calculators and tutorials that will help you to estimate motor size and battery power needed for a robot project.
