Topic: Recording Audio - Film Name Error (Read 658 times) previous topic - next topic
Tristans5
So I'm making a recording device hooked up to a rotary phone receiver, it is using the TMRpcm Library. Currently, the code I have is working perfectly with my build. The only problem is I want to be able to record an infinite amount of sound files. I had it with a Switch Case earlier but needed to manually name each file and could only reach a case limit of 10 before RAM became an issue. I have tried adding a variable as well as a string into the record line but I receive the error message below. The library states the startRecording() function must be written as such: void startRecording(char *fileName, unsigned int SAMPLE_RATE, byte pin, byte passThrough); and the stopRecording as such: void stopRecording(char *fileName);
Code: [Select]
/Users/Tristan/Documents/Arduino/SpeakerCorner/SpeakerCorner.ino: In function 'void loop()':
SpeakerCorner:41:63: error: no matching function for call to 'TMRpcm::startRecording(StringSumHelper&, int, const uint8_t&)'
       audio.startRecording(String(audiofile)+".wav", 16000, A0); break;
In file included from /Users/Tristan/Documents/Arduino/SpeakerCorner/SpeakerCorner.ino:4:0:
/Users/Tristan/Documents/Arduino/libraries/TMRpcm/TMRpcm.h:76:8: note: candidate: void TMRpcm::startRecording(char*, unsigned int, byte)
   void startRecording(char* fileName, unsigned int SAMPLE_RATE, byte pin);
/Users/Tristan/Documents/Arduino/libraries/TMRpcm/TMRpcm.h:76:8: note:   no known conversion for argument 1 from 'StringSumHelper' to 'char*'
/Users/Tristan/Documents/Arduino/libraries/TMRpcm/TMRpcm.h:77:8: note: candidate: void TMRpcm::startRecording(char*, unsigned int, byte, byte)
/Users/Tristan/Documents/Arduino/libraries/TMRpcm/TMRpcm.h:77:8: note:   candidate expects 4 arguments, 3 provided
SpeakerCorner:41:66: error: break statement not within loop or switch
SpeakerCorner:153:49: error: no matching function for call to 'TMRpcm::stopRecording(StringSumHelper&)'
     audio.stopRecording(String(audiofile)+".wav"); break;
/Users/Tristan/Documents/Arduino/libraries/TMRpcm/TMRpcm.h:78:8: note: candidate: void TMRpcm::stopRecording(char*)
/Users/Tristan/Documents/Arduino/libraries/TMRpcm/TMRpcm.h:78:8: note:   no known conversion for argument 1 from 'StringSumHelper' to 'char*'
SpeakerCorner:153:52: error: break statement not within loop or switch
THIS IS MY CODE BELOW
Code: [Select]
//////////////////////////////////////// SD CARD
#include <SD.h>
#include <SPI.h>
#include <TMRpcm.h>
#define SD_ChipSelectPin 10
TMRpcm audio;
//////////////////////////////////////// SWITCH CASE
int audiofile = 0;     // # of recording
unsigned long i = 0;
bool recmode = 0;      // recording state
int inPin = 2;         // input Switch Pin
int state = HIGH;      // the current state switch
int reading;           // the current reading from the switch
  pinMode(A0, INPUT);  // Microphone
  pinMode(inPin, INPUT_PULLUP); // Switch
  SD.begin(SD_ChipSelectPin);
  audio.CSPin = SD_ChipSelectPin;
  reading = digitalRead(inPin);
  while (i < 300000) {
    i++;
  i = 0;
  if (reading == LOW) {
    if (recmode == 0) {
      recmode = 1;
      Serial.println("Recording");
      audiofile++; // To move case
  else if (reading == HIGH) {
    recmode = 0;
    Serial.println("Hung-Up");
pert
The TMRpcm library's functions don't work with String. You will need to use regular strings (null terminated char arrays) instead:
http://www.cplusplus.com/reference/cstring/
You shouldn't be using String anyway.
Tristans5
Would the use of an int be a better idea? If so how would I properly implement that into the code as simply adding it before with a "+" is not working.
pert
Also posted at:
https://arduino.stackexchange.com/q/60046
If you're going to do that then please be considerate enough to add links to the other places you cross posted. This will let us avoid wasting time due to duplicate effort and also help others who have the same questions and find your post to discover all the relevant information. When you post links please always use the chain links icon on the toolbar to make them clickable.
pert
#4
Dec 27, 2018, 12:15 pm Last Edit: Dec 27, 2018, 12:16 pm by pert Reason: Add strcat link
Create a buffer with 13 elements (maximum 8 character file name + 1 for the dot + maximum 3 character extension + terminator):
Code: [Select]
char audioFilename[13];
Use itoa to convert the int to its base-10 string representation and put it in the buffer:
Code: [Select]
itoa(audiofile, audioFilename, 10);
use strcat to add the extension:
Code: [Select]
strcat(audioFilename, ".wav");
The buffer now contains the filename as a string, which you can pass to the tmrPCM library.
Tristans5
Code: [Select]
Code: [Select]
Code: [Select]
Thank you very much! This worked. Unfortunately, I am now receiving much poorer quality audio with a lot of noise. I am assuming this is something to do with the circuit which may require a capacitor.
pert
You're very welcome. I'm glad if I was able to be of assistance.
