Topic: La crosse WS- 2300 (Read 6444 times) previous topic - next topic
Fonzolino
I have a anemometer (wind speed sensor) from an La Crosse weather station (WS-2300) (up to 16 wind directions) and
Rain Gauge for WAS 2300-16-series. I'd like to connect it to my arduino.
It uses a standard RJ11 jack to transmit data. I opened it (wind speed sensor)- photo, up and saw that the RJ-11 pin-out is as followed:
1 - serial I / O
2 - VDD
3 - Regulator CE (Chip Enable)
4 - GND
Rain Gauge used Reed switch RJ-11 pin-out is as followed>
1 - DATA
4 - GND
How would I go about connecting it to my arudino, and then reading what's being sent over the serial line?
thanks
robtillaart
You apparently did not search the forum, check - http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1286087094
Rob Tillaart
Fonzolino
Thanks,
but this does not help me much.  If I look at other post is still anemometer connected to ovn pin, and wind vane to another. How is here?
tnx
robtillaart
1 - serial I / O
2 - VDD
4 - GND
There will be pulses from line 1, probably a square wave. You could use an interrupt routind to count these pulses. See - http://arduino.cc/en/Reference/AttachInterrupt
The minimal code should be like this
volatile unsigned long counter = 0;
  attachInterrupt(0, wind, RISING);   // IRQ 0 == PIN 2
  if (millis() - last > 1000)  // display counter once per second
    Serial.println(counter);
    last = millis();
void wind()
  counter++;
Rob Tillaart
