Topic: teensyduino code (Read 3115 times) previous topic - next topic
111swords
I have had an arduino for a year now and just got a teensyduino 2.0.
I am still having a hard time with the code.
I wanted to make a usb controller for my computer it wold have about ten buttons on it.
This is the code I found.
I wonted to add more buttons to the code but I cant.
Can some one help.
const int pinBtnUp = 0;
const int pinLEDOutput = 11;
//Variables for the states of the SNES buttons
boolean boolBtnUp;
  //Setup the pin modes.
  pinMode( pinLEDOutput, OUTPUT );
  //Special for the Teensy is the INPUT_PULLUP
  //It enables a pullup resitor on the pin.
  pinMode( pinBtnUp, INPUT_PULLUP );
  //Zero the SNES controller button keys:
  boolBtnUp = false;
//  //debugging the start button...
  digitalWrite ( pinLEDOutput, digitalRead(pinBtnUp));
  //Progess the SNES controller buttons to send keystrokes.
  fcnProcessButtons();
//Function to process the buttons from the SNES controller
void fcnProcessButtons()
  //Assign temporary values for the buttons.
  //Remember, the SNES buttons are read as active LOW.
  //Capture their status here:
  boolean boolBtnUp = !digitalRead(pinBtnUp);
  if ( boolBtnUp )
    //Set key1 to the U key
    Keyboard.set_key1( KEY_U );
    Keyboard.set_key1( 0 );
  //Send all of the set keys.
  Keyboard.send_now();
robtillaart
DOn't have a teensy but assuming that if your code works, this should give you insight how it is done.
(code not tested or compiled)
const int pinBtnDown = 1;  // assumption pin 1 is the down
boolean boolBtnUp = false;
boolean boolBtnDown = false;
  pinMode( pinBtnDown, INPUT_PULLUP );
  boolBtnDown = !digitalRead(pinBtnDown);
  if ( boolBtnUp )
  if ( boolBtnDown )
    Keyboard.set_key1( KEY_D );
Rob Tillaart
111swords
Thanks but when I type U or D once they don't stop.
I press the button once and instead of there being one d it does this dddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddddd.
111swords
jraskell
If you want to be able to handle more than 6 buttons, the code will get a bit more complicated as the USB Keyboard protocol only allows registering up to 6 keypresses at the same time (this is why the Teensyduino keyboard class has six separate methods for issuing a keypress).
Up to 6 buttons can be done fairly easily by duplicating this block of code:
  if ( boolBtnUp )
up to six times, changing the set_key# function that is called for each one, from set_key1() to set_key6().  As I said at the beginning though, writing code to handle  10 buttons becomes a non-trivial task (and you still would not be able to register more than 6 button presses at any one time)
robtillaart
You need to reset the boolean to false when the key is send!
  if ( boolBtnUp )
    BoolBtnUp = false;
  if ( boolBtnDown )
give it a try
Rob Tillaart
ds2ktj
Are you debouncing your inputs (either with hardware or another method?).  Pressing the button "once" it still bounces open and closed for a few milliseconds (perhaps up to a couple hundred)....in a loop that runs in micro seconds this looks like a whole ton of button presses.
http://www.arduino.cc/en/Tutorial/Debounce
This little web video explains this a bit and provides some details on various hardware debouncng strategies.
http://jeremyblum.com/2011/03/07/arduino-tutorial-10-interrupts-and-hardware-debouncing/
111swords
I tried BoolBtnUp = false; but they just keep on coming.
This is way harder than I thought. :smiley-roll-sweat:
111swords
Thanks for all of your help I got it to work.
This is my finished code
const int pinBtnDown= 1;
boolean boolBtnUp;
boolean boolBtnDown;
  boolBtnUp = false;
  boolean boolBtnDown = !digitalRead(pinBtnDown);
  if ( boolBtnUp )
    if ( boolBtnDown )
    Keyboard.set_key2( KEY_D );
    Keyboard.set_key2( 0 );
:D :D :D :D :D :D :D :D :D :D :D
PaulS
When you are going to have useless comments, at least they should be correct useless comments...
