Topic: [SOLVED] Can't get my accelerometer to work -- output seems random (Read 3325 times) previous topic - next topic
Daanii
I am using a MMA7361 board sold by Modern Device: shop.moderndevice.com/products/mma7260qt-3-axis-accelerometer
I hooked the accelerometer's Vin to the 5 Volt output on the Arduino, its GND to the ground on the Arduino, and its x, y and z outputs up to the analog inputs 0, 1 and 2 on the Arduino.
The problem is, my results make no sense. When I leave the accelerometer sitting on the ground stationary, I get results that bounce around.
Here's my code:
#define xInputPin 0
#define yInputPin 1
#define zInputPin 2
int xValue, yValue, zValue;
   // start serial port at 9600 bits per second
     xValue = analogRead(xInputPin);
     yValue = analogRead(yInputPin);
     zValue = analogRead(zInputPin);
     Serial.print("X Value");
     Serial.print("\t");
     Serial.print(xValue);
     Serial.print("\t");
     Serial.print("Y Value");
     Serial.print("\t");
     Serial.print(yValue);
     Serial.print("\t");
     Serial.print("Z Value");
     Serial.print("\t");
     Serial.print(zValue);
     Serial.print("\n");
Here's my results:
X Value 1023 Y Value 1023 Z Value 1023
X Value 0 Y Value 0 Z Value 0
X Value 890 Y Value 840 Z Value 810
X Value 869 Y Value 814 Z Value 784
X Value 850 Y Value 789 Z Value 755
X Value 831 Y Value 766 Z Value 731
X Value 798 Y Value 725 Z Value 690
X Value 806 Y Value 734 Z Value 698
X Value 830 Y Value 763 Z Value 729
X Value 884 Y Value 834 Z Value 806
X Value 992 Y Value 966 Z Value 936
X Value 34 Y Value 0 Z Value 0
X Value 835 Y Value 770 Z Value 738
X Value 1001 Y Value 980 Z Value 959
X Value 930 Y Value 868 Z Value 836
X Value 1023 Y Value 1023 Z Value 999
X Value 1023 Y Value 1007 Z Value 982
X Value 1005 Y Value 982 Z Value 958
X Value 899 Y Value 849 Z Value 819
X Value 1009 Y Value 986 Z Value 962
X Value 864 Y Value 807 Z Value 776
X Value 987 Y Value 956 Z Value 916
X Value 25 Y Value 0 Z Value 0
X Value 801 Y Value 729 Z Value 693
X Value 941 Y Value 879 Z Value 844
X Value 998 Y Value 974 Z Value 943
X Value 28 Y Value 0 Z Value 0
X Value 689 Y Value 600 Z Value 576
X Value 742 Y Value 659 Z Value 631
X Value 789 Y Value 714 Z Value 677
Am I missing something simple?
simon.monk
To me, they look too bouncy even to have any sense filtered into them.
Normally, you will need filtering (low pass is fine) in the code.
Something like:
Adjust alpha for the level of smoothing.
#define alpha 0.8
static double lastX = 0;
double newX = readAccelerometerX();
double smoothX = alpha * lastX + (1 - alpha) * newX;
lastX = newX;
// ditto for the other 2 axes
I write books about Arduino and Electronics: http://simonmonk.org
liuzengqiang
I have this accelerometer and it's working fine. When lying around, it's around 512 on every channel with a couple levels changing up and down, when I enabled 6g accuracy. Care to share a picture? How are you connecting it to arduino?
Daanii
Unfortunately, I can't put up a picture right now. But I have the accelerometer on a breadboard with wires from the x, y and z outputs and to the Vin and GND inputs. I've tried using both 5 Volts and 3.3 Volts to power the accelerometer.
So x, y and z should all be at about 512 when the jumper to select 6g accuracy is used? I thought the z axis would be different, due to gravity.
Thanks for the suggested filter code. I'll try that if I ever get some results that make sense.
liuzengqiang
Right I was thinking about my other 2-axis accelerometer. The z shows an offset from 512. The best way to get help is to post both pictures and code.
MarkT
Well the chip is 3.3V and the module has a regulator on board to drop to that, so powering with 5V to the modules Vin pin is the correct thing.
If you've connected 5V to the Vdd pin of the module I'm afraid you will have fried it.
The output voltages should be centred on 1.65V BTW.
Daanii
Thanks for the comments. Since it seemed as though my pin connections and code were as they should be, I checked the wiring and found a problem with my breadboard. Fixed that, and I'm getting good results now.
So now I'm ready to try the filtering and see what I can come up with. I'm going to use the accelerometer in a car to give feedback on the car's motion.
Thanks, all.
