Topic: Encoder Counting Using PIC (Read 5963 times) previous topic - next topic
RuH_iranga
Component:
16f877
POLOLU encoder motor  http://www.pololu.com/catalog/product/1447 2096 pulses per one shaft revolution.
Use RB0 interrupts and turn on the PORTB pull-up resistors.
use MikroC language.
Code: [Select]
int count=0;           // This count use in interrupt routine
void interrupt()               // enter when RB0 Falling
  if(portb.f0&portb.f1)         // By checking B0 and B1, Position and Direction Find
  {count++;                     // If "+" direction
  else                          // If "-" direction
  {count--;
  INTCON.INTF=0;                // Clear flag
void main()
     Pwm_Init(5000);
     PWM_Start();
     TRISB=0b11111111;          // B0 and B1 encoder inputs
     TRISD=0b00000000;          // Motor Control Pin
     INTCON=0b11010000;         // enable RB0 interrupts
     OPTION_REG=0b01000000;     // Enable portB internal PULL-UP resistors
                                // And Rising edge of RB0 int
     Pwm_Change_Duty(240);      // Whatever speed
     portd.f1=1;                // Motor drive to "+"
     portd.f0=0;
     while(1)
         if (count>4192)    // Count exceeds 4192(2 round), Stop
           portd.f1=0;
           portd.f0=0;
By changing RD0 and RD1 you can change motor direction, then it should be reduced the count. and also change the (count<-4192) you can ensure that program detect the position as well as direction. this just reading encoder and you can use it with your application. Also possible to use 10k external Pull-UPs on B0 and B1.
Thanks.
mowcius
Ok, I'm intrigued, why did you post it?
Is it in some way a question or Arduino related?
RuH_iranga
It may helps to someone like me. sorry for use C code.
mowcius
Quote
Possibly but not on this forum - this is the arduino forum and you just posted non-'arduino standard' code for a non-arduino chip.
Perhaps a PIC forum would be a better bet.
