Topic: Arduino Interrupt pins problem (Read 1 time) previous topic - next topic
ebarash
Dear All,
it seems a problem with my interrupt pin 2. I want to calculate the RPM of a motor. The simple code is quite well through int pin 3, but when I change it to int pin 2 the result is not correct. What should be the problem?
I check it on two arduino uno boards, same problem.
thanks
int ir_sensor = 2;
unsigned int ir_rpm = 0;
unsigned int numOfRotations = 0;
int pulsesPerTurn = 1;
unsigned long lastTime = 0;
void counter(){
    numOfRotations++;
    pinMode(ir_sensor,INPUT);
    attachInterrupt(digitalPinToInterrupt(ir_sensor), counter, FALLING);
void loop()  {
    stop_ir_Interrupt();
           Serial.print("  "); Serial.println(ir_rpm);
void stop_ir_Interrupt(){
     if(millis() - lastTime >= 1000){
        detachInterrupt(digitalPinToInterrupt(ir_sensor));
        ir_rpm = (numOfRotations * 60) / pulsesPerTurn;
        lastTime = millis();
        numOfRotations = 0;
KASSIMSAMJI
you should  declare your numOfRotations as ' volatile unsigned int ' as it appears in both main thread and the ISR routine
you can google what 'volatile ' means
Electrical Engineer
ebarash
well it is recommended to use variables as volatile inside interrupts. but It doesn't influence on your result generally.
I tried all of them and got same results.
the problem is, the result from pin2 and pin 3 are not same with same conditions!
KASSIMSAMJI
try  INPUT_PULLUP in pinMode
CHANGE over FALLING in attachInterrupt()
Electrical Engineer
ebarash
I tried all of them. I have different results!
Robin2
I use the program in this link to detect the speed of a small motor. Note how simple the ISR code is and how there is no need for detachInterrupt()
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
ebarash
...R
Thanks for your answare. The problem is with interrupt 0(pin2). I don't know why, but it does not give me the right answare. interrupt 1 (pin 3) is good and I don't have any problem with my code.
Robin2
Is that true with my program ?
...R
ebarash
...R
I used your code. It is working well on both of pins 2,3. Also my simple code is working well when I use a delay() (at leats with 100ms) in my void loop().
The problem comes when I don't use any delay in void loop. I am wondering about this result. What should be the problem?
The number of pulses per second should be counted inside interrupt function and finally the value will be printed in main loop! why this miskate happens without delay?
Robin2
So why not use it?
...R
ebarash
So why not use it?
...R
The reason is that I have some other datas which should be save in an array together with rpm and they are comming in several milliseconds, so I  cannot wait one second to save them.Your code has also one second delay to write pulses and without that is not working.
Robin2
That is not an important part of my program. I just did it like that so the info appears at a rate that makes sense for the human viewing the screen. There is no need to display the data and you can update things every time there is a pulse if you wish.
I don't know what you mean by "without that is not working"
...R
ebarash
...R
this is oart of your code.
I mean what if you remove the one second waiting time to show data?
    getIsrData();
//    (millis() - prevDisplayMillis >= 1000) {
//     prevDisplayMillis += 1000;
        showData();
pulses per second will not be true if you unable those lines!
Robin2
You don't need a 1 second interval to know the pulse rate. All you need to know is the interval between two pulses (or the interval between a larger number if you want an average.
And even if you do want to show the data once per second the rest of your program does not have to be limited to once per second.
Rather than pick small holes in specific pieces of code that were just prepared as a typical example why not tell us exactly what you want to achieve?
...R
ebarash
...R
Thanks for your advices but the problem is I am very curious about pin 2 which is not stable as pin 3. It seems there is a problem with timing. With 1 second intervals to show data it works well( or with baud rate of lower than 9600), but without that delay only pin 3 gives me the right results. Pin 2 is not stable and gives the higher rpm. even with your nice code it will happens.
At all, I don't have any problem with my code because I am using pin3.
Just to know if someone had same problem or knows the reason. Because it happens even with a very simple code.
