Topic: Trouble with SK6812 Mini LEDs (Datasheet pinout not matching behaviour) (Read 2079 times) previous topic - next topic
lmal
Hi all!
First time poster so please feel free to give me feedback on the clarity of my question.
I have purchased 2 sets of SK6812 Mini LEDs from 2 different suppliers for a project that I am working on. Unfortunately, both sets of LEDs are behaving in a manner that seems to contradict the datasheets that I have been provided.
This is a screenshot from a datasheet that I have been using:
This is the code I have been using (tried on both a Arduino Uno "Freetronics" knock-off and a Arduino Mega 2560)
Code: [Select]
#define PIN 8
// Parameter 1 = number of pixels in strip
// Parameter 2 = pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(2, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.setBrightness(10);
  strip.show(); // Initialize all pixels to 'off'
  strip.setPixelColor(1, strip.Color(255, 0, 0));
  strip.setPixelColor(0, strip.Color(255, 0, 0));
  strip.show();
  strip.setPixelColor(1, strip.Color(0, 255, 0));
  strip.setPixelColor(0, strip.Color(0, 255, 0));
  strip.show();
I wired up a test LED according to the datasheet:
And connected it to the Uno using the guidelines given on this website for NeoPixels (https://learn.adafruit.com/adafruit-neopixel-uberguide/powering-neopixels) i.e. capacitor between the voltage and ground connections, resistor in series on the data signal and got nothing.
I then tried seeing if I had perhaps mixed up the pins while soldering and noticed something odd. If I connected the "DOUT" pin to the 5V and left the "VDD" pin unconnected, the LED behaved exactly how I expected (correct colour and delays as per the above code). Setup below (apologies for wires going everywhere):
So I then thought that maybe the "DOUT" and "VDD" pins have been mixed up and that I would just have to wire in accordance to this pinout:
But I did this to no avail. The 2nd LED in series does not respond to any commands issued from the "DOUT" pin (originally VDD) if I assume the above pinout is correct.
I'm at a loss now as to what the problem could be. I have already received my custom PCBs that I was hoping to wire the LEDs onto but if the pinouts aren't matching what I thought they would be the PCBs are more or less useless. As I stated earlier, this is the second order of LEDs that are behaving like this so I'm almost certain it is something I am doing rather than a problem with the datasheet but I can't figure out what.
Please let me know if you think you can help or need anymore information! Thanks  :)
Grumpy_Mike
Sorry but the pictures have insufficient resolution for be to check you have it right. But one thing puzzles me, why is the Dout connected to anything? For just one LED it should be not connected to anything.
Also each LED requires a 0.1uF ceramic across it does it not?
lmal
Hi Mike,
Thank-you for your response. Sorry I should've made myself clearer, once I decided that the pins may be a different pinout to what I was expecting I tested the possible "DOUT" pin (actually VDD on the datasheet) with a LED that I have already soldered onto my PCB (with the 0.1uF ceramic capacitor across the VDD and GND terminals). LED2 did not work in this configuration (i.e. the data signal did not seem to go from Uno -> LED1_DIN -> LED1_DOUT -> LED2_DIN), but both the LEDs work if I just give them data direct from the Uno.
Does this make sense? I can take some more photos if that would be helpful?
Grumpy_Mike
Quote
That suggests you are doing something wrong. You need to look at the Dout on an oscilloscope to see what sort of waveform you are getting, but I guess you haven't got access to one.
Quote
Din and Dout are at opposite corners as are 5V and ground. They have to be like that to make connecting them on a strip work.
lmal
I have tried to substitute an oscilloscope by using regular "breadboard" (for want of a better term) LEDs connected at the +ve pin to data and -ve pin to ground.
The LED that is connected to the data out from the Uno is flickering at intervals consistent with the colour changes written in the code (so I think this is what I want from a DOUT pin?). The second LED that is wired up after DOUT (VDD originally) is not flickering but is just on?
Grumpy_Mike
Quote
Sorry but there is no way you can tell that from looking at a flickering LED. The data is going at 800KHz, anything above 60Hz just looks like it is on all the time.
Sorry but I don't know what else to advise.
lmal
Sorry I should've been clearer - the LED was flickering on/off at 1000ms intevals (everytime the colours on the SK6812s changed).
That is okay, thankyou very much for your help thus far. I will update if I come to a solution.
lmal
Update: found the problem! The solder had not actually created a connection between the VDD pin and the pad. Should've checked my soldering more thoroughly before posting - thanks for the help regardless Mike :)
Grumpy_Mike
OK glad you got it going.
That sort of thing might have been spotted with a photograph but is trick to spot with just words.
lmal
shubham90
The SK6812 is a set smart control circuit and one of the controlled LED source. The LED has a low driving voltage which allows for environmental protection and energy saving, high brightness, good consistency, low power, and long life.
Paul__B
And - your point is?  :smiley-eek:
Compared to the WS2812 devices that seem to burn out at "the drop of a hat", you seem to have demonstrated a most impressive robustness of this particular device!  :smiley-cool:
Grumpy_Mike
Quote
Well I thought it was a poor attempt at spam.
