Topic: Serial Input Basics: example 5, question (Read 2202 times) previous topic - next topic
brice3010
Jan 14, 2019, 08:23 pm Last Edit: Jan 14, 2019, 08:27 pm by brice3010
This thread gives an outstanding explanation of the use of serial communications:
http://forum.arduino.cc/index.php?topic=396450.0
Robin2 gives in example 5 a means to send in one message various values: integer, float, character,..
I use this with succes to send 3 floats, 2 integers and one character by HC-12 radio.
Example: <99.99,22.25,3.47,11,22,A>
However, from time to time the receiver crashes when receiving messages; using serial monitor debugging I discovered that the receiving controller always crashes while processing the last string (the character, A).
To debug, I inserted serial output prints after each parsing command:
Code: [Select]
  strtokIndx = strtok(tempChars, ",");     // get the first part - a float
  integer1FromPC = atof(strtokIndx);     // convert this part (first value) to a float: dutycycle
  Serial.print(F("   1 "));
  strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
  integer2FromPC = atof(strtokIndx);     // convert this part (second value) to a float: temperature
  Serial.print(F(" 2 "));
  integer3FromPC = atof(strtokIndx);     // convert this part (third value) to a float: battery voltage
  Serial.print(F(" 3 "));
  integer4FromPC = atoi(strtokIndx);     // convert this part (fourth value) to an integer: minutes past the hour
  Serial.print(F(" 4 "));
  integer5FromPC = atoi(strtokIndx);     // convert this part (fifth value) to an integer: hour of the day
  Serial.print(F(" 5 "));
  strcpy(messageFromPC, strtokIndx); // this is a text string: copy it to messageFromPC:
  // sensor identification, sensor "A" or sensor "B", or C or D
  Serial.println(F(" 6 "));
When a crash occurs, I still get the value "5" on the serial monitor, but not the value "6", always.
This is the same parsing code as used in Robin2 example 5.
I suspect that once in a while the message is corrupted during transmission and that either a null character or something else that is not right is being received.
Would it be possible to include code that distinguishes, in the message to be parsed, whether there are either 0 or null values, or some other way to prevent the code execution to cause the controller to crash?
Deva_Rishi
how have you declared
Code: [Select]
messageFromPC ? as a char * i suspect but what size ? (the terminating \0 needs to be part of the string)
To 'Correct' you have to be Correct. (and not be condescending..)
vaj4088
As usual, it would be useful to provide the ENTIRE code instead of just a snippet.
brice3010
Code: [Select]
Code: [Select]
const byte numChars = 32;
char receivedChars[numChars];
char tempChars[numChars];        // temporary array for use when parsing
// variables to hold the parsed data
char messageFromPC[numChars] = {0};
float integer1FromPC;  // value1 (dutycyclevalue=soil moisture level)
float integer2FromPC;  // value2 (temperature at soil moisture sensor)
float integer3FromPC;  // battery voltage
int integer4FromPC;  // integer minutes (transmission time-instance, minutes past the hour)
int integer5FromPC;  // integer hour (transmission time-instance, hour of the day)
32 bytes, actually taken from Robin2's example. Would that be correct in this context?
brice3010
I would gladly do that but it is 1035 lines of code; and I think the issue is with a very specific part, in the parsing section: so with all due respect I hope to spare you the nightmare of wading through what might be avoided maybe by starting with the part that starts the crash and MCU restart?
vaj4088
You may have avoided one nightmare but created another by forcing unpaid helpers to play guessing games and ask questions about unseen portions of the code.
Do you REALLY want your help delayed?
brice3010
#6
Jan 14, 2019, 10:18 pm Last Edit: Jan 16, 2019, 05:36 pm by brice3010
Here you go, I hope this helps; thanks in advance.
cattledog
Code: [Select]
When parsing the last piece, strtok is looking for a ',' which does not exist. In testing, it has not appeared to make a difference between using strtok(NULL, NULL) or strtok(NULL, ","), but perhaps there is something in your case which does make a difference.
There are two thing to test.
First, see if strtok(NULL,NULL) improves things.
Second, try formulating the transmitted string like this with a period after the letter
<99.99,22.25,3.47,11,22,A.>
Then parse with
strtok(NULL, ".")
brice3010
#8
Jan 14, 2019, 10:56 pm Last Edit: Jan 14, 2019, 11:01 pm by brice3010
Code: [Select]
Then parse with
strtok(NULL, ".")
Great, thanks a lot for that, I had not noticed this.
Just a question here: would/could there be a reason why most of the received messages do get parsed succesfully?
Then, your suggestion is to include a . after the A however should that not be a , ?
For sure I will be testing both suggestions and let you know asap.
EDIT: sorry, I misread your suggestion "..parse with strtok(NULL, "."); evidently this requires A.
Robin2
#9
Jan 14, 2019, 11:19 pm Last Edit: Jan 14, 2019, 11:20 pm by Robin2
Can you make a short program that illustrates the problem? I suspect it would help you as well as us.
...R
PS ... I have not tested my examples on an ESP8266.
Two or three hours spent thinking and reading documentation solves most programming problems.
cattledog
Quote
My guess would be that in the rare, failing case, there is no null terminator.
If there is no null terminator on receivedChars[] or tempChars[] I believe that the behavior of strtok will be undefined when parsing the last piece. The esp8266 also has a pretty short watchdog timer which causes resets if things get blocked
Why there would be a missing '\0' is a mystery.
brice3010
...R
Good idea, will be done asap. Results and program will be posted.
brice3010
The strtokIndx = strtok(NULL, NULL); resulted in continual crashes, no parsing possible. Next will be the A. test as well as a bare-bones program version (Robin2).
cattledog
#13
Jan 15, 2019, 07:01 am Last Edit: Jan 15, 2019, 07:04 am by cattledog
Quote
Actually this might be a clue if you have done this correctly. Did you only replace the last use of strtok for the message and the printing of the 6. The earlier cases should have been left unchanged.  If that is the situation for this test, then there must be something wrong with the null termination.
Code: [Select]
  strtokIndx = strtok(NULL, NULL);// this continues where the previous call left off
 //strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
Actually, I have higher hopes for the addition of another token after the A.  It could be a ',' or a '.' --just another character that strtok is looking for instead of the end of the string when looking for a non existent ','.
brice3010
Code: [Select]
Indeed, only the last use of strtok had been changed.
Next today the A. test and corresponding strtok change will be done.
