Topic: Controlling 2 RGB stips with 1 UNO. Is it possible? (Read 864 times) previous topic - next topic
jmstech1
Hi everyone! I'm new here and to Arduino but loving it!
I've played with some simple coding samples and managed to power up a 1/2 meter strip of 5050 RGB lights...changing colours etc through pins 4,5,6. But can I also power up a second strip of RGB through pins 11, 12 and 13 at the same time? Having them flash at different times? Maybe it's been done before but I'm a newbie. :D
Thanks for any help in advance!!
John
pert
Wawa
Flashing (on/off) can be done with any pin,
but only the PWM pins 3, 5, 6, 9, 10, and 11 can be used for brightness control.
Leo..
jmstech1
Thank you Pert and Leo for answering that question which has been bugging me for days! Are there samples of codes I can analyze?
Right now I'm tinkering with simple codes like:
int redPin = 5;
int greenPin = 6;
int bluePin = 3;
//uncomment this line if using a Common Anode LED
//#define COMMON_ANODE
    pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
    setColor(255, 0, 0);  // red
  setColor(0, 255, 0);  // green
etc..
Wondering if I'm heading in the wrong direction with my limited knowledge on coding.
Greatly appreciate the fast response here. Wasn't expecting that!
John
Grumpy_Mike
#4
Jan 15, 2019, 07:26 am Last Edit: Jan 15, 2019, 07:30 am by Grumpy_Mike
Quote
Yes you have just posted it. Unfortunately you have not posted it all and correctly. See the how to use this forum sticky post. It looks like you are using a libiary but you missed that from your code. There is no need to use a libiary simply use an analogWrite for each PWM pin you want to set.
Simply add the extra pins like you have the origional ones. What are you using to drive the LED strips? Transistors or FETs? You can't run the strips off just the outputs.
pert
I assumed you weren't using PWM since in the first post you said you were using pin 4, which doesn't have PWM functionality. Now I see you're actually using pins 3, 5, 6.
I recommend studying File > Examples > 02.Digital > BlinkWithoutDelay and the associated tutorial:
https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
And use the millis() technique instead of delay(). That will make it easy to flash each strip independently without any timing interference between the two.
jmstech1
Hi Grumpy_Mike,
Yes my bad for not posting all the codes. I am using FETs to drive these lights on a bread board. 6 in total with resistors to accommodate each.
pert: OK so I will check the link out to give me something to study. Once again greatly appreciate the great help here! :D
John
jmstech1
OK so looking over the 2 types of examples suggested, I'm not too sure which is the best method I should go about. My goal is to use 2 strips of 5050 RGB LEDs. Each strips needs to 3 wires (red, green blue) connected to Arduino for instructions. Both LED strips share ground on the breadboard so I got that covered. Getting 1 LED strip to work is easy but trying to have 2 LED strips alternate flash is where I'm stumped.
John
pert
I suggested the BlinkWithoutDelay example. What was the other one?
Grumpy_Mike
If you want to extend what you have done and you want us to help then you have to post all your code. You are using some sort of library that you have not said what it is. The full code will contain a #include statement and that will tell us what libiary you are using.
jmstech1
Hi guys,
Ok so here is the codes and hopefully I will see the light here... no pun intended. :D
John
Code: [Select]
JMSTECH RGB LED test1
int redPin = 5;
int greenPin = 6;
int bluePin = 3;
  setColor(0, 0, 255);  // blue
  setColor(255, 255, 0);  // yellow
  setColor(80, 0, 80);  // purple
  setColor(255, 255, 255);  // white
  setColor(0, 255, 255);  // aqua
  delay(100);
  setColor(0, 0, 0);  // off
  delay(100);
  delay(100);
  delay(100);
  delay(700);
  delay(700);
  delay(700);
  delay(700);
  delay(700);
  delay(100);
void setColor(int red, int green, int blue)
  #ifdef COMMON_ANODE
    red = 255 - red;
    green = 255 - green;
    blue = 255 - blue;
  #endif
  analogWrite(redPin, red);
  analogWrite(greenPin, green);
  analogWrite(bluePin, blue);
Grumpy_Mike
Well the code is quite appalling and I would not start from this point.
However, this is the simplest way to extend your code to add another strip. Basically the pin numbers are put in an array and the array index is passed to the setColor function, by the way you spelled colour wrong.
Code: [Select]
byte redPin[] = {5,11};
byte greenPin[] = {6,12};
byte bluePin[] = {3,13};
  setColor(255, 0, 0,0);  // red strip 0
  setColor(255, 0, 0,1);  // red strip 1
  setColor(0, 255, 0,0);  // green strip 0
  setColor(0, 0, 255,1);  // blue strip 1
  setColor(255, 255, 0, 0);  // yellow strip 0
  setColor(80, 0, 80,1);  // purple strip 1
  setColor(255, 255, 255,0);  // white strip 0
  setColor(0, 255, 255, 1);  // aqua strip 1
  delay(100);
  setColor(0, 0, 0, 0);  // off strip 0
  setColor(0, 0, 0, 1);  // off strip 1
  delay(100);
 // rest of code missing due to being fed up you get the idea by now.
void setColor(byte red, byte green, byte blue, byte strip)
  #ifdef COMMON_ANODE
    red = 255 - red;
    blue = 255 - blue;
  #endif
  analogWrite(redPin[strip], red);
  analogWrite(greenPin[strip], green);
  analogWrite(bluePin[strip], blue);
jmstech1
#12
Jan 18, 2019, 04:37 pm Last Edit: Jan 18, 2019, 04:39 pm by jmstech1 Reason: Typo
Ahhh... Thanks Mike, will try this out tonight after work! Oh....I didn't spell colour wrong...lol, thats me fooling around with sample code made by others. I think there is a American version of "color" and Canadian version of "colour". To-mae-toes, to-maa-toes... :-P
John
Grumpy_Mike
Quote
Indeed there is an American version but I am English and seeing I am the one giving the advice, I win.  ;)
jmstech1
Yes....you win. I can't argue with that. Hahaha!!!
