Topic: UDP parsePacket() doesn't work after send() (Read 513 times) previous topic - next topic
Mark81
Jan 18, 2019, 06:32 pm Last Edit: Jan 18, 2019, 06:33 pm by Mark81
It seems that after sending an UDP packet I can't receive others anymore.
Here my code:
Code: [Select]
#include <LwIP.h>
#include <STM32Ethernet.h>
#include <EthernetUdp.h>
#include <OSCMessage.h>
#include <OSCBundle.h>
#include <OSCData.h>
#include <Servo.h>
byte mac[] = { /* ... */ };
byte ip[] = { 192, 168, 0, 222 };
const unsigned int port = 9999;
byte outIp[] = { 192, 168, 0, 250 };
const unsigned int outPort = 9999;
EthernetUDP Udp;
OSCErrorCode error;
long previousMillis = 0;
  Ethernet.begin(mac, ip);
  Udp.begin(port);
void led_handler(OSCMessage &msg, int patternOffset)
  // do something
  Serial.println("received!");
void sendBundle(int ch)
  OSCBundle bundle;
  char address[32];
  sprintf(address, "/led/%u", ch + 1);
  bundle.add(address).add((int32_t) 1).add((float) 0.05);
  Udp.beginPacket(outIp, outPort);
  bundle.send(Udp);
  Udp.endPacket();
  Serial.println("sent!");
void processOSCMessage(void)
  OSCBundle bundle;
  int size = Udp.parsePacket();
  if (size > 0)
    while (size--) bundle.fill(Udp.read());
    if (bundle.hasError())
      error = bundle.getError();
      Serial.print("error: ");
      Serial.println(error);
      bundle.route("/led", led_handler);
  processOSCMessage();
  if(currentMillis - previousMillis > 5000) {
    sendBundle(1);
Every 5 s it sends out the UDP packet, but it receives the incoming packets only before sending out the first one.
Am I missing anything obvious?
pylon
Don't you think it might be an error in the STM32 implementation only?
Code: [Select]
Mark81
I don't know... that's why I asked here :)
You are aware of such a problem? Or, do you see any error in my code?
pylon
Quote
STM32 is not a broadly used platform on the Arduino IDE.
Quote
Code: [Select]
beginPacket() accepts either an IPAddress object or a character array (which your argument is) but in that case it expects a DNS name. Your value is neither the string of an IP address nor a DNS name (which couldn't be resolved anyway as the DNS server is missing).
That might be a problem but I cannot see why it really sends a correct packet but stops receiving them. Might be some interaction with the try to contact the DNS server. Try with correct types and post results.
