Topic: need help with code (Read 269 times) previous topic - next topic
vosologist
im new to coding and im making a school project for a phone controlled car and its not working any ideas
Code: [Select]
#define LOGGING
// Device drivers
// Enable one driver in each category
// Motor controller:
#define ENABLE_ADAFRUIT_MOTOR_DRIVER
// Distance sensor
#define ENABLE_NEWPING_DISTANCE_SENSOR_DRIVER
// Remote control:
//#define ENABLE_BLUESTICK_REMOTE_CONTROL_DRIVER
#define ENABLE_ROCKETBOT_REMOTE_CONTROL_DRIVER
#include <SoftwareSerial.h>
SoftwareSerial BTSerial(BT_RX_PIN, BT_TX_PIN);
#ifdef ENABLE_ADAFRUIT_MOTOR_DRIVER
#include <AFMotor.h>
#include "adafruit_motor_driver.h"
#define FRONT_LEFT_MOTOR_INIT 1
#define BACK_LEFT_MOTOR_INIT 2
#define FRONT_RIGHT_MOTOR_INIT 3
#define BACK_RIGHT_MOTOR _INIT 4
#endif
#ifdef ENABLE_BLUESTICK_REMOTE_CONTROL_DRIVER
#include "bluestick_remote_control.h"
#define REMOTE_CONTROL_INIT
#endif
#ifdef ENABLE_ROCKETBOT_REMOTE_CONTROL_DRIVER
#include "rocketbot_remote_control.h"
#define REMOTE_CONTROL_INIT 10,50
#endif
#include "logging.h"
#include "moving_average.h"
namespace envirobot
    class Robot
    public:
         * @brief Class constructor.
        Robot()
            : frontleftMotor(FRONT_LEFT_MOTOR_INIT), backleftMotor(BACK_LEFT_MOTROR_INIT), frontrightMotor(FRONT_RIGHT_MOTOR_INIT),backrightMotor(BACK_RGHT_MOTOR_INIT),
              distanceSensor(DISTANCE_SENSOR_INIT),
              distanceAverage(TOO_CLOSE * 10),
              remoteControl(REMOTE_CONTROL_INIT)
            initialize();
        void initialize()
            randomSeed(analogRead(RANDOM_ANALOG_PIN));
            remote();
        void run()
            unsigned long currentTime = millis();
            int distance = distanceAverage.add(distanceSensor.getDistance());
            RemoteControlDriver::command_t remoteCmd;
            bool haveRemoteCmd = remoteControl.getRemoteCommand(remoteCmd);
            log("state: %d, currentTime: %lu, distance: %u remote: (%d,l:%d,r:%d,k:%d)\n",
                state, currentTime, distance,
                haveRemoteCmd, remoteCmd.left, remoteCmd.right, remoteCmd.key);
            if (remoteControlled()) {
                if (haveRemoteCmd) {
                    switch (remoteCmd.key) {
                    case RemoteControlDriver::command_t::keyF1:
                    // switch back to remote mode
                    remote();
                else {
                    if (moving()) {
                        if (obstacleAhead(distance))
                            turn(currentTime);
                    else if (turning()) {
                        if (doneTurning(currentTime, distance))
                            move();
    protected:
        void remote()
            frontleftMotor.setSpeed(0);
            backleftMotor.setSpeed(0);
            frontrightMotor.setSpeed(0);
            backrightMotor.setSpeed(0);
            state = stateRemote;
        void move()
            frontleftMotor.setSpeed(255);
            backleftMotor.setSpeed(255);
            frontrightMotor.setSpeed(255);
            backrightMotor.setSpeed(255);
            state = stateMoving;
        void stop()
            state = stateStopped;
        bool obstacleAhead(unsigned int distance)
            return (distance <= TOO_CLOSE);
        bool turn(unsigned long currentTime)
            if (random(2) == 0) {
                frontleftMotor.setSpeed(-255);
                backleftMotor.setSpeed(-255);
            else {
                frontrightMotor.setSpeed(-255);
                backrightMototr.setSpeed(255);
            state = stateTurning;
            endStateTime = currentTime + random(500, 1000);
        bool doneTurning(unsigned long currentTime, unsigned int distance)
            if (currentTime >= endStateTime)
                return (distance > TOO_CLOSE);
            return false;
        bool moving() { return (state == stateMoving); }
        bool turning() { return (state == stateTurning); }
        bool stopped() { return (state == stateStopped); }
        bool remoteControlled() { return (state == stateRemote); }
    private:
        Motor frontleftMotor;
        Motor backleftMotor;
        Motor frontrightMotor;
        Motor backrightMotor;
        RemoteControl remoteControl;
        enum state_t { stateStopped, stateMoving, stateTurning, stateRemote };
        state_t state;
        unsigned long endStateTime;
envirobot::Robot robot;
    BTSerial.begin(9600);
    robot.run();
Delta_G
#1
Jan 21, 2019, 04:50 pm Last Edit: Jan 21, 2019, 04:51 pm by Delta_G
Your code works.  It does exactly what it is written to do.  If you want it to do something different then you're going to have to take a little time to actually communicate with us a little about what it is that you want and how that differs from what it does now.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
vinceherman
Why is everything double-spaced?
Excess use of white space makes it hard to read.
Get rid of the extra lines.  A single blank like before a function is OK.
And as Delta-G says, better describe your issue.
What did you expect it to do?
What does it actually do?
How do those two differ?
