Topic: Bathroom Occupancy Project (Read 206 times) previous topic - next topic
jacobdubois
I'm looking to build a system that turns on a light when the deadbolt is locked (assuming pressure plate sensor?).
I'll need two lights. 1 is close to the door & could be wired but the other is in the other room & would need to receive the data wirelessly.
Any idea on parts I would need for something like this? I couldn't find a project quite like this online but if you know of one, please let me know.
ChrisTenone
What, I need to say something else too?
wolframore
#2
Jan 23, 2019, 04:47 pm Last Edit: Jan 23, 2019, 04:49 pm by wolframore
couple comments... perhaps you can figure it out with the following:
1. deadbolt sensor... can be a cherry switch, a contact switch meaning if it's metal wires from one side will conduct though each sides. may require two switches to complete a return if the power and sensor it on one side.
You will have to adjust the design for your situation.
On the first light you can do this with nothing other than a power source and light, switches and perhaps some resistors based on what you're using.
If you want remote light you might use WiFi or Bluetooth.  Just using a bluetooth device would be enough in this situation.  It senses a closed circuit and sends a I'm locked signal to the other device.  The other device get's a locked signal and triggers on a light.
Hope this helps.
Chris you're really quick... that project would not know if the deadbolt is locked... just that the door is closed... so OP would still have to figure out the deadbolt sensor.  But it should help with the coding... to me it looks like overkill :)
Bad boys rate our young girls but Violet goes willingly :)
- this is a mnemonic from BEC
jacobdubois
Thanks, Chris. That'll be a helpful guideline. I've seen a lot of motion sensor projects but haven't found pressure plate or contact switch ones.
Thank you, wolframore. That's certainly helpful.
Any tips on which arduino I should be using?
dave-in-nj
We were just talking about this sort of thing.  we expanded since the economy rebounded and the 'preferred' ladies bathroom is in constant use.
We were talking about putting an OCC/Un-OCC sensor so people at their desk can find the status.
My thoughts are a web page and a place to put  your name.  so you can say you are next.
maybe ESP8266 hosting a super simple web page
I just ordered the OCC sensor that will turn on the lights
and  VOC sensor to turn on the fan and allow it to stay on.
small magnets on door, like for an alarm system.
Paul__B
In my "work" rooms, I have magnetic latches on the toilet doors, presently controlled by a wall switch, but later to be controlled by proximity plates (i.e., no touch!).  Upgrade will include RFID to allow "emergency" access (someone collapses).  Obviously, the power to the latch itself is a semaphore that can be extended wherever required.
If someone switches on the latch and exits, shutting the door behind, we simply switch off the power to that system and reset it.  The RFID keys will more easily solve that situation.  I am considering ESP8266s.
Delta_G
#6
Jan 23, 2019, 11:12 pm Last Edit: Jan 23, 2019, 11:13 pm by Delta_G
Is the bathroom actually any better that way?  Like just using it to do your business?  Or does most of the satisfaction come from the design and build?
How were we ever able to pee without technology?
IMHO, if someone has to explain to you how to work the bathroom, then the bathroom is WAY overcomplicated.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
Paul__B
Yes, I take your point; the thing must be "idiot proof".  We have had some problems already with people (mostly male I think - must ask the secretary about this ...) simply not locking the door, mostly more from general vagueness (habit?) than not understanding the switch.
The significant complications are only in regard to the ability to unlock the door in "emergency" situations - specifically, someone collapses inside.  That has happened in the past, hopefully not too frequently, but always a significant risk.
Other than that, it is simply a switch marked "Door lock", presently with a red/green LED.  Only the fact that it is not actually on the door itself differentiates it from a conventional snib.  A display which says "LOCKED" would be a logical extension both on the inside and "OCCUPIED" on the outside.  There is already a red LED on the electromagnet at the top of the door frame.
