Topic: PoolMaster: a comprehensive and smart home-pool automation system (Read 827 times) previous topic - next topic
Loulou74
Hey folks,
I'd like to present the solution I developped to regulate and monitor my pool.
The full project can be found here:
https://github.com/Loic74650/PoolMaster
Brief description:
Three main metrics are measured and periodically reported over MQTT and an LCD screen: water temperature, PH and ORP values.
Pumps states, tank-level states and other paramters are also periodically reported.
Two PID regulation loops are running in parallel: one for PH, one for ORP.
PH is regulated by injecting Acid from a tank into the pool water (a relay starts/stops the Acid peristaltic pump).
ORP is regulated by injecting Chlorine from a tank into the pool water (a relay starts/stops the Chlorine peristaltic pump).
Defined time-slots and water temperature are used to start/stop the filtration pump for a daily given amount of time (a relay starts/stops the filtration pump).
A lightweight webserver provides a simple dynamic webpage with a summary of all system parameters. An XML file with more info is available at http://ARDUINO_LOCAL_IP/Info.
Communication with the system is performed using the MQTT protocol over an Ethernet connection to the local network/MQTT broker.
pert
It looks very nice. Thanks for sharing!
Loulou74's pictures:
Loulou74
Thanks Pert (and wow, that's a *large* Git you have)
I did not know we could integrate the pics intot he posts, thank you
pert
Quote
I've done a lot of pull requests this year! Unfortunately some people are very slow to merge them so I have a big collection of forks.
It's a little more tricky than it ought to be. Here's a guide for how to do it:
http://forum.arduino.cc/index.php?topic=364156
Loulou74
Hello Folks,
Small update on my pool-monitoring system.
- code now directly compiles for both Controllino or Arduino Mega2560 hardwares. Simply select the hardware you have in the IDE prior to compiling.
- example below of an integration of the system into a cloud-based smartphone app (Blynk) via Mosquitto and NodeRed.
- new LCD screens with added water pressure monitoring
Happy Spring
