Topic: FPGA Signature Generation (Read 572 times) previous topic - next topic
jwestmoreland
Hello All,
How are the signatures generated in VidorBoot.cpp:
#include "VidorBoot.h"
__attribute__ ((used, section(".fpga_bitstream_signature")))
const unsigned char signatures[4096] = {
   //#include "signature.ttf"
   0x00, 0x00, 0x00, 0x00,
   0x4d, 0xdc, 0x03, 0x00,
   0x93, 0x86, 0xad, 0x47, 0x75, 0xb0, 0x56, 0x96, 0x79, 0x64, 0xc5, 0x36, 0x12, 0xcf, 0x18, 0xce, 0xfe, 0x8a, 0xeb, 0xa2, 0x45, 0x86, 0x44, 0xfe, 0x7c, 0x45, 0x8a, 0xa9, 0x49, 0x46, 0xa7, 0xe1,
   0x00, 0x00, 0x00, 0x00,    /* TAG 0 == BOOTLOADER */
   0x01, 0x00, 0x00, 0x00,      // Set force flag; always flash this bitstream, even if the checksums match
   0x00, 0x00, 0x06, 0x00,
   0x12, 0x33, 0x1F, 0x00,
   0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
   0x01, 0x00, 0x00, 0x00,      /* TAG 1 == USER BITSTREAM */
   0x00, 0x00, 0x10, 0x00,
   0xD7, 0xAA, 0x08, 0x00,
   0x02, 0x00, 0x00, 0x00,      /* TAG 2 == USER DATA */
__attribute__ ((used, section(".fpga_bitstream")))
const unsigned char bitstream[] = {
   #include "boot.ttf"
Thanks In Advance,
John
Limba
Usually signature is generated when you crate app.tff with makeCompositeBinary command.
In this VidorBoot case it contains FPGA boot image and it have signature for it and this seems also clear rest of the flash.
jwestmoreland
OK, I see this in the create_image.sh script:
FOLDER_NAME=${PWD##*/}
if [ x$PROJECT_NAME == x ]; then
PROJECT_NAME=$FOLDER_NAME$LITE
fi
if [ -d software/softcore ]; then
echo create ram + flash app.ttf
elf2flash --input=build/software/$FOLDER_NAME/$PROJECT_NAME.elf --output=build/output_files/$PROJECT_NAME.flash --base=0x008E0000 --end=0x008FFFFF --verbose --save
nios2-elf-objcopy --input-target srec --output-target binary build/output_files/$PROJECT_NAME.flash build/output_files/$PROJECT_NAME.bin
../../TOOLS/makeCompositeBinary/makeCompositeBinary -i build/output_files/$PROJECT_NAME.ttf:1:512,build/output_files/$PROJECT_NAME.bin:0:896 -o build/output_files/app.ttf -t 1 > build/output_files/signature.h
echo create ram app.ttf
../../TOOLS/makeCompositeBinary/makeCompositeBinary -i build/output_files/$PROJECT_NAME.ttf:1:512 -o build/output_files/app.ttf -t 1 > build/output_files/signature.h
fi
Is there an example of where the nios_xx.bin file is made?
Thanks,
John
Limba
If nios_xx is project name then the bin file is created from nios_xx.elf and that is compiled in build_launncher.sh, build_launcher_interna.sh or build_sw.sh.
jwestmoreland
I am seeing these bin files that have been made by the build process:
$ find ./ -name "*.bin" -print
./VidorBitstream/projects/MKRVIDOR4000_graphics/build/output_files/MKRVIDOR4000_graphics_lite.bin
./VidorBitstream/projects/MKRVIDOR4000_peripherals/build/output_files/MKRVIDOR4000_peripherals_lite.bin
./VidorBitstream/projects/MKRVIDOR4000_template_mbox/build/output_files/MKRVIDOR4000_template_mbox_lite.bin
And I see these .elf files:
 find ./ -name "*.elf" -print
./VidorBitstream/projects/MKRVIDOR4000_graphics/build/software/launcher/launcher_lite.elf
./VidorBitstream/projects/MKRVIDOR4000_graphics/build/software/MKRVIDOR4000_graphics/MKRVIDOR4000_graphics_lite.elf
./VidorBitstream/projects/MKRVIDOR4000_peripherals/build/software/launcher/launcher_lite.elf
./VidorBitstream/projects/MKRVIDOR4000_peripherals/build/software/MKRVIDOR4000_peripherals/MKRVIDOR4000_peripherals_lite.elf
./VidorBitstream/projects/MKRVIDOR4000_template_mbox/build/software/launcher/launcher_lite.elf
./VidorBitstream/projects/MKRVIDOR4000_template_mbox/build/software/MKRVIDOR4000_template_mbox/MKRVIDOR4000_template_mbox_lite.elf
But I need to verify if the scripts/build process are discerning between the lite and standard FPGA tools during the build process.
I am not sure right now how that is done via the current build scripts nor is it currently clear how the scripts determine which build to make; other than kicking this off via the Quartus build tools.
There's no current build script command that tells the scripts to use the "lite" version vs. the standard/pro version is there?  Maybe I'm just missing this right now.
Thanks,
John
Limba
This is begin of all scripts
if [ `quartus_sh --version | grep Lite | wc -l` == "1" ]; then
So it's asking version from quartus shell. That should have lite word there if it's not full version.
jwestmoreland
Limba,
OK, I see that in the "build_all.sh" script -
and
build_launcher.sh and
build_launcher_internal.sh and
build_sw.sh .
Thanks,
John
