Looks like you've got two pieces of code trying to use the same interrupt vector. Probably two libraries trying to use the same timer or something. If you'd posted your code I might be able to spot it, but you chose to make sure I wasn't able to do anything like that. So I'll leave it to you to do some searching on the internet and see if a couple of your libraries are incompatible.
