Topic: Arduino UNO + MKS Mass Flow Controller (Read 412 times) previous topic - next topic
ATSS
Jan 29, 2019, 05:23 pm Last Edit: Jan 29, 2019, 05:28 pm by ATSS
Hi to all! I'm new in this forum.
My name is Alessandro and I'm a Chemist. I would like to interface Arduino UNO with some old MKS Mass Flow Controllers. They have a serial port with 15 pin and I konw the meaning of each one (in the follow):
1# MKS Test Point
2# Flow Signal Output
3# Valve Close
4# Valve Open
5# Power common
6# -15 VDC
7# +15 VDC
8# Set Point Input
9# No Connection
10# Optional Connection
11# Signal Common
12# Signal Common
13# No Connection
14# No Connection
15# Chassis Ground
I would like to use it like flow reader and/or like flow regulator.
Would it be possible? If yes, how must I proceed with  the connection and with the sketch?
Thanks to everyone who can help me!
Best regard,
Alessandro
jremington
#1
Jan 29, 2019, 06:50 pm Last Edit: Jan 29, 2019, 06:52 pm by jremington
You need to know the voltage levels of the signals, and the meaning of that voltage level. If the signal is a serial signal, then you need to know the serial data protocol.
If they are not either 0 or 5V, then you need some sort of interface between the device and a 5V Arduino.
ATSS
stefa24
https://sites.google.com/site/agritronica/
https://sites.google.com/site/t3chconcrete/
https://www.youtube.com/channel/UCnY1DNrSywgadjyqqtbvyew
