Topic: i2c.h Wont compile without errors (Read 930 times) previous topic - next topic
Cdjd44
I have a sketch that works on an Uno but will not compile when trying to upload to an mrk wifi 1010. The problem seems to be with the i2c library I am using found here:
https://github.com/orgua/iLib/blob/master/src/i2c_BMP280.h
I am trying to connect a 262-BMP280 barometer:
https://www.mouser.co.uk/ProductDetail/Bosch-Sensortec/BMP280?qs=QhAb4EtQfbUP9Z%252bCHM3Wyg%3D%3D
Here is the sketch:
Code: [Select]
#include <Wire.h>
#include "i2c.h"
#include "i2c_BMP280.h"
BMP280 bmp280;
String EAR = "RIGHT";
    Serial.begin(57600);
    bmp280.initialize();
    // 1-0-0    122Hz
    // 2-0-0    96Hz
    // 4-0-0    68Hz
    // 16-0-0   28Hz
    val > 15  VAL_CTRL_OSRS_P16
    val > 7   VAL_CTRL_OSRS_P08
    val > 3   VAL_CTRL_OSRS_P04
    val > 1   VAL_CTRL_OSRS_P02
    val > 0   VAL_CTRL_OSRS_P01
    bmp280.setPressureOversampleRatio(1);               // Ultra-high resolution?
    val > 15  VAL_FILTER_16;
    val > 7   VAL_FILTER_08;
    val > 3   VAL_FILTER_04;
    val > 1   VAL_FILTER_02;
    bmp280.setFilterRatio();                           // (disabled?) Infinite Impulse Response filter
    ms > 3000 VAL_SB_4000;
    ms > 1500 VAL_SB_2000;
    ms > 750  VAL_SB_1000;
    ms > 350  VAL_SB_0500;
    ms > 180  VAL_SB_0250;
    ms > 90   VAL_SB_0125;
    ms > 31   VAL_SB_0062;
    bmp280.setStandby();                               // ((fastest) Oversampling: 0.5
    // onetime-measure:
    bmp280.setEnabled(0);
    bmp280.triggerMeasurement();
    bmp280.awaitMeasurement();
    float pascal;
    bmp280.getPressure(pascal);
    Serial.println(EAR + " " + pascal);
And here is the error message:
Code: [Select]
Arduino: 1.8.8 (Windows 10), Board: "Arduino MKR WiFi 1010"
In file included from sketch\i2c_BMP280.ino.cpp:1:0:
C:\Users\cdjd4\Documents\Arduino\libraries\I2C-Sensor-Lib_iLib\src/i2c.h: In constructor 'WirePlus::WirePlus()':
C:\Users\cdjd4\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\cores\arduino/Arduino.h:116:37: error: no match for 'operator|=' (operand types are '_EPortType' and 'long unsigned int')
 #define bitSet(value, bit) ((value) |= (1UL << (bit)))
C:\Users\cdjd4\Documents\Arduino\libraries\I2C-Sensor-Lib_iLib\src/i2c.h:70:5: note: in expansion of macro 'bitSet'
     bitSet(PORTC, 4);  // deactivate internal pull-ups for twi
C:\Users\cdjd4\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\cores\arduino/Arduino.h:116:37: note: candidate is:
C:\Users\cdjd4\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\cores\arduino/Arduino.h:116:37: note: operator|=(_EPortType&, long unsigned int) <built-in>
C:\Users\cdjd4\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.20\cores\arduino/Arduino.h:116:37: note:   no known conversion for argument 1 from '_EPortType' to '_EPortType&'
C:\Users\cdjd4\Documents\Arduino\libraries\I2C-Sensor-Lib_iLib\src/i2c.h:71:5: note: in expansion of macro 'bitSet'
     bitSet(PORTC, 5);  // as per note from atmega8 manual pg167
In file included from C:\Users\cdjd4\Documents\Arduino\i2c_BMP280\i2c_BMP280.ino:5:0:
C:\Users\cdjd4\Documents\Arduino\libraries\I2C-Sensor-Lib_iLib\src/i2c.h:73:5: error: 'TWBR' was not declared in this scope
     TWBR = ((F_CPU / 400000L) - 16) / 2;
exit status 1
Error compiling for board Arduino MKR WiFi 1010.
option enabled in File -> Preferences.
I must admit that c/c++ are not my main languages, I mostly work with c# and this is my first arduino project. I have spent the last week looking at this and could not find any answers which I think might be due to my lack of experience with the language. Any help or pointers would be most appreciated.
DrGee
#1
Feb 04, 2019, 04:56 pm Last Edit: Feb 04, 2019, 05:03 pm by DrGee
I do not have that sensor, but I took a brief look at your post and both headers.
In my opinion, the library can not be used with the MKR1010 because of the atmega-specific coding that is employed (which is reasonable for an atmega but not for the SAMD21 on the mkr1010).
While you could painstakingly try to fix things, it would be ill-advised.
Again, IMO, you would be much better off trying to use the BOSCH driver here: https://github.com/BoschSensortec/BMP280_driver
The readme has examples for I2C initialization and reading etc...
Now, I don't have that sensor and have not tried that driver, but I am hoping this will help...let us know please.
Edited to add: I also notice that they have an Arduino library here with some instructions for use with samd boards that might be useful https://github.com/BoschSensortec/BSEC-Arduino-library
Cdjd44
Thank you so much for getting back to me with some options and I apologize for the delay. I was genuinely losing my mind trying to get the library working. I will look at both suggestions and get back to let you know if I have found some success or not.
StevenBL
Hallo,
After my purchase of the MKRWIFI1010 the same problem occurred. The options for a solution mentioned earlier seemed pretty tough to do.
Looking into the possible solutions the special library called  BMx280MI in the list shown by the library tool of the Arduino IDE was found.
The info on the lib is at
https://bitbucket.org/christandlg/bmx280mi/overview
Does not use i2c.h and i2c_bmp280.h but  Wire.h and BMx280MI.h.
The example in that repositry worked for me. Have a look at
https://bitbucket.org/christandlg/bmx280mi/src/b1ed6eea7a5071f56cd590d06e783109a211be5b/examples/BMx280_I2C/?at=master
and the corresponding sketch
https://bitbucket.org/christandlg/bmx280mi/src/b1ed6eea7a5071f56cd590d06e783109a211be5b/examples/BMx280_I2C/BMx280_I2C.ino?at=master&fileviewer=file-view-default
Maybe it works for you as well. Combining with WIFININA and MQTT was OK.
