Topic: Webserver problem (Read 723 times) previous topic - next topic
jozzy
So i've been trying to figure out what i've done wrong for almost 4 hours now, and i still didnt fixed it.
The problem is: i got 4 leds, but when i try to put led 1 on, all go on..
And when i put led 1 off, led 1 goes off, and rest stay on..
But if i want to put led 2 off after that led 1 goes on!!
So: all other leds goes on whatever i do!!
Here is the part of the code with the problem:
Code: [Select]
Client client = server.available();
if (client) {
while (client.connected()) {
if (client.available()) {
c = client.read();
if (readString.length() < 30) {
readString.concat(c); }
if (c == '\n') {
Le = readString.indexOf("L=");
if (Le > 1){
// LED1 //
  if (readString.substring(Le,(Le+5))== "L=1on");{
    digitalWrite(LED1, HIGH);
    LED1CHECK = true;}
  if (readString.substring(Le,(Le+6))== "L=1off"){
    digitalWrite(LED1, LOW);
    LED1CHECK = false;}
// LED2 //
  if (readString.substring(Le,(Le+5))== "L=2on");{
    digitalWrite(LED2, HIGH);
    LED2CHECK = true;}
  if (readString.substring(Le,(Le+6))== "L=2off"){
    digitalWrite(LED2, LOW);
    LED2CHECK = false;}
client.println("Content-Type: text/html");
client.println();
// LED1 //
client.println("<form method=get name=LED1>");
client.println("<font size='10'>LED status: ");
if (LED1CHECK == true){
Serial.println("LED1 is aan");
client.println("<font color='green' size='10'>ON</font>");
client.println("<input type='submit' name='L' value='1off' style='width: 50%; height: 15%; font:50px;'></form>");}
if (LED1CHECK == false){
Serial.println("LED1 is uit");
client.println("<font color='grey' size='10'>OFF</font>");
client.println("<input type='submit' name='L' value='1on' style='width: 50%; height: 15%; font:50px;'></form>");}
// LED2 //
client.println("<form method=get name=LED2>");
if (LED2CHECK == true){
Serial.println("LED2 is aan");
client.println("<input type='submit' name='L' value='2off' style='width: 50%; height: 15%; font:50px;'></form>");}
if (LED2CHECK == false){
Serial.println("LED2 is uit");
client.println("<input type='submit' name='L' value='2on' style='width: 50%; height: 15%; font:50px;'></form>");}
Im almost sure its an easy mistake, but i just cant find it
Thanks a lot in advance!!
jozzy
I dont know why it works now but i changed every second if into an else if and it worked T_T
Thnx anyway guys!!
