Topic: Invalid Library (MKR1000 and MKRMotorCarrier in MATLAB)  (Read 803 times) previous topic - next topic
hlodemel
- Arduino 1.8.8
- MATLAB R2018b
I get the "Invalid library" error when trying to run the "arduinosetup" with USB:
I have followed the instructions by copying the MKRMotorCarrier folder into the "libraries" folder.
The folder is listed:
listArduinoLibraries
ans =
 7×1 cell array
   {'Adafruit/MotorShieldV2' }
   {'Arduino/MKRMotorCarrier'}
   {'I2C'                    }
   {'RotaryEncoder'          }
   {'SPI'                    }
   {'Servo'                  }
   {'ShiftRegister'          }
I get the following error message in MATLAB:
feb 02, 2019 2:40:49 PM com.mathworks.hwservices.logging
INFO: Loading configuration...
Initializing packages...
Preparing boards...
Verifying...
C:\ProgramData\MATLAB\SupportPackages\R2018b_1\3P.instrset\arduinoide.instrset\arduino-1.8.1\arduino-builder -dump-prefs -logger=machine -hardware C:\ProgramData\MATLAB\SupportPackages\R2018b_1\3P.instrset\arduinoide.instrset\arduino-1.8.1\hardware -hardware C:\ProgramData\MATLAB\SupportPackages\R2018b_1\3P.instrset\arduinoide.instrset\idepkgs\packages -tools C:\ProgramData\MATLAB\SupportPackages\R2018b_1\3P.instrset\arduinoide.instrset\arduino-1.8.1\tools-builder -tools
Invalid library found in D:\Dokumenter\Arduino\libraries\MKRMotorCarrier: D:\Dokumenter\Arduino\libraries\MKRMotorCarrier
C:\Users\Helge\AppData\Local\Temp\ArduinoServer\MW\sketch\ArduinoServer.ino.cpp:1:
c:\programdata\matlab\supportpackages\r2018b_1\3p.instrset\arduinoide.instrset\idepkgs\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1\arm-none-eabi\include\c++\4.8.3\arm-none-eabi\armv6-m\bits\c++config.h:429:30: fatal error: bits/cpu_defines.h: No such file or directory
#include <bits/cpu_defines.h>
compilation terminated.
exit status 1
I don't know what to do, and would really appreciate a little help :)
spycatcher2k
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
pert
Looks like you didn't follow the instructions correctly. Please post a link to where you found these instructions.
The "Invalid library" thing is only a helpful warning telling you that the Arduino IDE found something that was not a library in a libraries folder. That is NOT an error. This is the error:
Code: [Select]
That error is unrelated to the invalid library warning.
